Author Topic: Dummy Guide to fitting remote central locking  (Read 184945 times)
Offline spudboy6
  • Just like a golf ......
Re: Dummy Guide to fitting remote central locking
« Reply #50 on: 13 January 2013, 15:03 »
Ahh right yeah, they're the ones that connect to green/grey on the loom. I'll fit a siren at some point I reckon.
[/quote
I'm looking into wiring the indicators up just want to find a way to do it without cutting the loom up ?
Offline spikenipple
« Reply #51 on: 13 January 2013, 20:51 »
Use the scotchlocks that come with the kit to connect the two brown wires (rcl loom) to the black/white and black/green wires coming from the bottom right plug underneath the steering column plastics.
Offline spudboy6
« Reply #52 on: 13 January 2013, 22:11 »
Mines In the boot mate I got their plug and play loom so no wire cutting apart from sorting lock and unlock an the indicators ,
Offline spikenipple
« Reply #53 on: 14 January 2013, 18:52 »
I have no idea in that case, sorry. Unless you run the wires to the dash?  :undecided:
Offline spudboy6
« Reply #54 on: 14 January 2013, 20:59 »
He wires are the same colour at the lamps.  So I got some connector pins wedged them in the back of the plug and run them like that
Offline GTi Grez
  • Getting there.....
« Reply #55 on: 21 January 2013, 16:52 »
Can you post a link for that plug and play kit  :smiley: The pdf looks good. I'm interested in seeing if they have a plug and play alarm and remote central locking kit....if not the one for about £40 looks alright.
Offline spudboy6
« Reply #56 on: 21 January 2013, 18:55 »
http://www.rclick.co.uk/product_info.php?cPath=69&products_id=995
Offline Callum_K
« Reply #57 on: 14 February 2013, 18:28 »
Bought a Rclick kit and installed it today...took 5 minutes and works faultless. Didn't bother with the plug n play cable, it's so easy to do its really not worth the fifteen quid.
If installing in the boot by the pump do as follows.
White from Rclick loom to grey on pump
White/ black to green on pump.
Black to brown on pump which is earthed on a stud on the rear quarter.
Yellow, yellow black and red to the red/ white on pump which is the 12v supply
One brown to black/green on drivers side light cluster
Second brown to black/white on passenger side cluster.
This was all done with the supplied quick crimp thingys. Plugged in to the box and worked perfectly!
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #58 on: 15 February 2013, 15:41 »
With the last two connections did all of the indicators light including the front?
Offline spudboy6
« Reply #59 on: 15 February 2013, 18:09 »
Yea only need to wire one per side and all indicators that side work
