Author Topic: lowering ??  (Read 1042 times)
Offline mk3troubles
lowering ??
« on: 10 August 2009, 21:07 »
i have fitted boge turbo shocks and eibach 30mm lowering springs and i am happy with the ride but when i fitted them and dropped it onto the floor i noticed theres only about an inch gap between rear bumpstop and the shock.been running it a few weeks now and it is very hard at the back.do i need to cut them down?what have you done ??thanks
Offline boneybradley
  • Back in a Mk3...
Re: lowering ??
« Reply #1 on: 10 August 2009, 21:10 »
i cut my originals in half when i first lowered mine (or you can buy powerflex one's)
Re: lowering ??
« Reply #2 on: 10 August 2009, 23:28 »
As above trim in half.
Offline mk3troubles
Re: lowering ??
« Reply #3 on: 11 August 2009, 17:23 »
sorted it now .it was squashing the bumpstops when it was stood.ended up with hardly any thing left ,i would have liked to have left the dust sheild in but there was nothing to hold it.anyway its much better now abit softer at the back end and the annoying squeek has gone :smiley:
only thing is its a bit lower now .the front could do with being 10-20mm lower but i already scrape the spoiler sometimes.
need to swap rear beam bushes asap too.its never ending :sad:
Re: lowering ??
« Reply #4 on: 12 August 2009, 08:45 »
Be carefull cutting too much off the bumpstop as it could bottom out and damage the shock.
Offline mk3troubles
Re: lowering ??
« Reply #5 on: 12 August 2009, 16:56 »
i left the fat bit on the top.
Re: lowering ??
« Reply #6 on: 12 August 2009, 17:13 »
Should be ok then.
