Author Topic: Fitted TSI-spec DV  (Read 18935 times)
Offline AlanD
  • MK5 2.0T 16v
Re: Fitted TSI-spec DV
« Reply #20 on: 12 August 2009, 18:19 »
If its the standard GTI you have to get underneath the car...
Later models (not sure what year this came into effect) and ED30s have them located in a much easier place and can be replaced via opening the bonnet.
Any pics showing it - mines 07 and don't fancy gettting the axle stands out  :grin:
You mean pics of my DV?  I dont have any Im afraid and I cant take any unless I get under my car, which I cant lol
Offline Micky 32
« Reply #21 on: 12 August 2009, 18:20 »
You got a D valve from the dealer for £26?
Yep, i got it sent from a dealer in NI, 26 + 4 or 5 for post.
2008 Octavia vRS race blue, xenons, parking sensors. Mods: Evom's, TBE milltek, Autotech fuel pump, Forge twintercooler, KO4, 325bhp on JKM RR
Offline Kermit
« Reply #22 on: 12 August 2009, 20:52 »
Was just a general request - thought you might have had the easier bonnet setup so could take a pic :grin:  Just ordered a Haynes manual so hopefully that will point me in the right direction - you guys know way too much about what goes on under the bonnet  :embarassed:
2007 GTI, Steel Grey, DSG with Paddle, Leather, 18" Monza, Xenons, Lux and Winter Pack, iPod, Tints
Offline AlanD
  • MK5 2.0T 16v
« Reply #23 on: 12 August 2009, 20:57 »
lol no, mines a MY05 so had to get under the car to replace mine.
Offline Teutonic_Tamer
« Reply #24 on: 13 August 2009, 12:47 »
Certainly made a differance to my car too, although my original DV was completley knackered with mutiple splits in the rubber!  :undecided:
Can only assume that because it's designed for a small engine with supercharger/turbo it holds the boost for longer so the little 1.4 doesn't struggle at the top end of rev range?
Sam
Its designed for the new 2.0 tsi in the scirocco and new gti.  Its actually quite a different engine
It's designed for all 2.0T engines as it supercedes existing ones,
WRONG.  It was specifically designed for ONLY the latest Audi-developed TSI engine with valvelift - as the part number clearly designates!
it's the only DV you can get now.
Wrong again.  The current part number for the original 200/230/240/265PS TFSI engine is still valid, and is still 'orderable'.
I ordered mine as a G valve and they sent me a D.
Ever heard of humans making mistakes?  :wink:
I feel like a homo
« Reply #25 on: 13 August 2009, 12:58 »
Also is this the same as the re-circulating valve or different??
I think its the same, I think its also called a cut of valve.
Forge used to have a guide for changing the DV on the 1.8T, maybe they have the same for the 2.0T.  If its the standard GTI you have to get underneath the car...
Actually, from what I can tell, the Recirculating Valve is what we refer to as the PCV, the DV is in fact an EGR cut off valve.
Nope, that is wrong.  IIRC, the 'correct' term VWAG now use is 'turbo cut off valve'.  This is also commonly known as a 'recirc valve' or 'divert valve', and also incorrectly known as a 'dump valve'.  This simply deals with excess boost pressure from the turbo.
The PCV is actually a 'positive crankcase ventilation' valve, and ONLY deals with excess pressure build up in the crankcase (usually caused by 'blow-by' gassses).  This has nowt to do with the turbo.
And EGR is 'exhaust gas recirculation' valve, a device for emissions control !!!  :nerd:
I feel like a homo
Offline Jammin
« Reply #26 on: 13 August 2009, 13:20 »
Sorry to seem beligerent, but it's important to get the terminology right when ordering parts.
You're right, in the workshop manuals it labels the valve at the front of the engine on the top of the manifold as a PCV ('pressure control valve'), but if you talk to VW they won't have a clue what you're talking about. That part, as far as they are concerned, is called a Recirculation Valve (or 'Recirc Valve'). I know this because I spoke to them today.
As for the DV (Diverter Valve), this is again not a term that VW will understand, they know this part as an 'EGR cut off valve' and if you ask for the latest part number, they will quote you '06H 145 710 D'.
This latest part (designed for newer 2.0 engines) superceeds all previous versions and even though it wasn't specifically designed for the MK5 GTi engine, still works with it.
Again, I know this because I had it fitted last month.
Offline Jammin
« Reply #27 on: 13 August 2009, 13:22 »
Sam
From my (very) recent experience, if you try and order an older version of this part from VW, they will tell you that it has been superceeded with '06H 145 710 D'. I have this part fitted on my car and it works perfectly, improving dramtically the B version that I previously had, even though this B version was (visibily) undamaged or ripped.
Offline Micky 32
« Reply #28 on: 13 August 2009, 13:47 »
[/quote]
Wrong :wink:, it IS the only DV that is available now as it supercedes the older version G, i have a friend who works in a dealer and has confirmed it. Unless of course the dealer or VW :wink: has old stock they want to get rid of then you will get the older one  :wink:
 Yes humans do make mistakes but not in this case
« Reply #29 on: 13 August 2009, 15:59 »
Erm . . . . you might want to read my sig.  I certainly know the correct terminology for specific parts, and I certainly know the difference between said parts to!  :rolleyes:
Just because some thicko at a dub stealer doesn't know the correct terminology, that doesn't mean that highly qualified and conciencious persons should be 'dummed down'!
I'll state again, a PCV has sod-all to do with regulating boost pressure from a forced induction system!  :rolleyes:
Well that just proves they have it wrong.  For ages now, ETKA has that part listed as a 'turbo cut off valve', however, it used to be called either a diverter valve or a recirculation valve - and VWUKs own parts ordering system may still be using the 'old' terminology.
Sorry, but that is utter horse sh!t.  A 'DV' and an 'EGR' are two very different components, and work on two completely different areas of an engine.  Someone really is talking out of their tail!
Just because a part 'fits', it categorically does NOT mean it superceeds it.  The piston DV was specifically designed for the Audi valvelift engine, which is in the new 'Rocco', and the Mk6 GTI - which is why the first three digits of the p/n are 'ahead' of the p/n range for the 'Mk5' TFSI engine.
I accept that some peeps have fitted the newer piston DV to a Mk5 TFSI engine - but I can categorically assure you - this is NOT an official supercession!
I feel like a homo
