Author Topic: Uprated bulbs for Hella Quin (Quad/Twin) Lights  (Read 11178 times)
Offline Adam
Re: Uprated bulbs for Hella Quads
« Reply #10 on: 10 August 2009, 13:09 »
Yea I'v got 6k, it makes a huge change.
They may take a bit longer to warm up than mine but they will still work, also I had a little problem of the headlight switch sending a trickle of power to the HIDs when on side lights, this ment they flickered, so got myself a Relay kit from eBay-
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190249975174#ebayphotohosting
They are so easy to wire up,
Down Hill From Here.
Offline Adam
« Reply #11 on: 10 August 2009, 13:10 »
Just make sure its the kit that does both main and dip beam,there is several kits out there especially on ebay that only do dip beam and this will fail the mot.
What since when, H1s only do dipped beam?  :huh:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #12 on: 10 August 2009, 14:39 »
oooo this is interesting now
 need a few more peeps to comment on what is fact......
Offline Adam
« Reply #13 on: 10 August 2009, 14:47 »
He has his facts wrong, mine passed the mot with this.
He is getting confused with the H4 bulb that is ment to have 2 filliments (Dipped and main beam) used in the lower spec Golfs.
Offline funkyfive
« Reply #14 on: 10 August 2009, 21:04 »
So what did you do about yr main beam?
Offline Adam
« Reply #15 on: 10 August 2009, 21:09 »
They are on the inner lens, why would you change them? Outer lens does dipped ONLY (Thats the projector that the HIDs go onto) and inner does sidelights and main beam-
This is with main beams on
« Last Edit: 10 August 2009, 21:11 by GTiAdam »
Offline funkyfive
« Reply #16 on: 10 August 2009, 21:24 »
Looks good, i am sold. Did you install the fogs yourself as my golf does not have them?
Offline Adam
« Reply #17 on: 10 August 2009, 21:27 »
:afro: You wont look back!
Nope mine came with them. My car is not a "J" Reg btw,
Offline funkyfive
« Reply #18 on: 10 August 2009, 21:31 »
lol. Damn looks like I will have to wire some in.
"Just wanted to say your interior looks the nuts!!!"
« Last Edit: 10 August 2009, 21:36 by funkyfive »
