Author Topic: Pollen Filter Quick Question, price?  (Read 1519 times)
Offline pablo64
Re: Pollen Filter Quick Question, price?
« Reply #10 on: 17 August 2009, 12:31 »
Hi, im a newbie on here, so hi all, just been reading this post, iv a 97 preg TDI and my blower is really crap as in air vents and screen, but the fan itself does sound quite powerful,  wasnt sure if the ducting has come off etc, but after reading your replys could it not be blowing as strong because my pollen filter is blocked, cheers and thanks in advance
Paul
Offline miyagigoose
« Reply #11 on: 18 August 2009, 00:51 »
Sounds like same problem as mine had, they get covered with leaves and crap which can really restrict airflow, VW say to change them about ever 20k or so, so its worth doing.
If the water drainage holes get clogged up like mine did they can also get damp and they get worse, plus smell bad, and  even worse if the water  builds up so high it comes inside the car :(
The plastic scuttle panel cover is fiddly and can get brittle with age so be carefull when taking it  off to get to the filter...
