Author Topic: slight oil burning  (Read 1549 times)
Offline cam_paseo
slight oil burning
« on: 04 August 2009, 18:27 »
As the title suggests i seem to be burning oil now.
Not sure how fast its burning it yet as light came on but before this i didnt check it, but does the 1.8t normally burn any oil?
only done 60k, no visible smoke,
gtigolfthree
Re: slight oil burning
« Reply #1 on: 04 August 2009, 18:37 »
Is it the oil pressure light thats coming on, have you checked the oil level?
Offline cam_paseo
« Reply #2 on: 05 August 2009, 21:15 »
Checked the oil level and topped it up lol it was on minimum.
Offline Rhyso
« Reply #3 on: 05 August 2009, 21:17 »
is the engine standard or modified?
Offline blown the case
« Reply #4 on: 06 August 2009, 18:41 »
Hi there
I too have a 1.8 20v turbo, and of late I have noticed a little oil consumption may be half a litre in 2 months and 2500 miles, albeit hard miles !! Like you, no smoke or rattles. Its been remapped by the lads at Rtech and does get a bit of a work out. Saying that I have only just run it in ....110 K later !!
From asking similar questions myself it would seem that they do tend to use a bit, according to the handbook its normal
How much is it drinking ?
99 GTi 1.8 20 valve Turbo : Forge DV, R Tech remap, Carbon Air box / intake
Offline cam_paseo
« Reply #5 on: 17 August 2009, 19:56 »
Just checked this again and bad bad news.
Its lost 1L of oil in 2 weeks, Still no bad smoking.
No power loss but i think it maybe the turbo as i took off the large black pipe going to the throttle body and it had oil sitting in it.
More investigating tomorrow as i will take off the bottom pipe, bet its full of oil.
Its standard by the way.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #6 on: 17 August 2009, 20:06 »
Sounds like the oil seals have perished in the turbo.  :(
I'm surprised you haven't seen any grey smoke coming out of the exhaust??  :undecided:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline cam_paseo
« Reply #7 on: 17 August 2009, 20:25 »
havent really taken much notice.
I dont want to replace the turbo then it turns out its something else, how can i be sure? its only done 60k.
Offline cam_paseo
« Reply #8 on: 18 August 2009, 18:48 »
Any other ways of knowing if its definately the turbo seal's apart from what ive already done?
