Author Topic: ECP and Engine Light ON!!  (Read 2741 times)
Offline Rhyso
Re: ECP and Engine Light ON!!
« Reply #10 on: 04 August 2009, 21:11 »
Ok cheers
How would this be done? Is it a dealer job?
AMD Essex should be able to have a look for you and their prices will be cheaper than your dealer  :wink:
is your car still in warranty though?? notice you mentioned its an 06.  If so get your dealer to sort it
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 04 August 2009, 21:13 »
Ok cheers
'fraid so... they don't share that with independents unfortunately! I bet you're just out of warranty too :undecided:
if you stamp your feet though they might help with the costs... i've heard of a few mk5 ecu's go now, very strange indeed.
You can try AMD but it may just be another case of paying for a fault code read and then being directed to the dealer :sad:
Offline kell
« Reply #12 on: 05 August 2009, 20:07 »
Hi Dan,Had the exact same problem last week and it turned out to be a faulty accelerator pedal.My mechanic knew straight away as it was the third one he  has replaced in a month.The unit cost 210 Euro from a main dealer in Dublin and 40 Euro labour.I have never had so many problems with a car!
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 05 August 2009, 20:12 »
i very much doubt you had the same fault code if it was a pedal fault?
Offline danowen49
« Reply #14 on: 06 August 2009, 19:33 »
Thats interesting..... was it same code though?
