Author Topic: oil light flashing on my vr6  (Read 1980 times)
Offline bhpamzz
« on: 03 August 2009, 01:15 »
what could this possibly be, my oil is fine???
the car has no powewr left and has the judders??
help pleaseeee
Offline ace
Re: oil light flashing on my vr6
« Reply #1 on: 03 August 2009, 08:15 »
have a look at the oil pressure switch. there should 3 on top of the oil filter, one of them is the oil pressure switch, the other two i think are temperature switches.
the judders, have u checked the basics, MAF, leads, coilpack???
Offline bhpamzz
« Reply #2 on: 03 August 2009, 11:10 »
well my leads are fine, coil pack is fine, now maf i dont know.
also i did take off the mani and the throttle could this be why??
i am also not getting any power it makes all the right noises but aint going nowere though.
you rekon my throttle would need re-calibrating??
and also could that oil light flashing be causing the loss of power as in putting the car into limp mode or something.
the oil light only flashs before i start the car once the car is started it doesnt flas at all.
please help!!!!!!!! im banging my head on a brick wall here guys  :embarassed:
Offline VR6_Wherry
« Reply #3 on: 03 August 2009, 15:22 »
Have a look at this:
http://www.golfgtiforum.co.uk/index.php?topic=124862.0
This could have been a possible issue when you took the manifold off and the throttle maybe...worth checking anyways as the symptoms are the same.
Sounds like your having lots of problems with your VR!! :(
Offline Mikester
  • Civic Type R
« Reply #4 on: 03 August 2009, 15:46 »
Probably would want to advise not driving it too much until the light is fixed. It could mean oil temp possibly?
Does the light flash when u start it? Or only when its warm? Have a look at the oil temp on the display when warm.
Offline bhpamzz
« Reply #5 on: 04 August 2009, 02:13 »
i am having a lot of probs with it.
my oil light only flashes when i turn on the ingnition. im going to check that link out.
thanks
