Author Topic: flat spots in the gear range  (Read 832 times)
Offline omex_uk
« on: 02 August 2009, 23:34 »
right i have a 95 8v gti and it seems that through most gears theres a flat spot between about 3k and 3400.
some one said it may be the air mass meter, is this a likely cause?
the car doesnt stop accelerating it just slows (feels like its holding back all the torque) and then seems to get a bit better at higher revs
locin78
Re: flat spots in the gear range
« Reply #1 on: 03 August 2009, 00:04 »
Hi, right on my 16v i had this prob it was the fuel relay, you maf sensor could be the prob but try the relay 1st as its the cheapest option , take your car for a  run for 10 mins, then feel the fuel relay if cold then change it it warm its ok. maf sensor are cheapest at VW they will do an exchange for about £90 hope this info helps.
Nic
Offline damien010685
« Reply #2 on: 21 August 2009, 14:49 »
Hi there i have the exact same problem my family's friend is a VW mechanic and he said most likely will be the air meter however thanks for the tip on the fuel relay i guess il know once its chanegd its in the workshop just now a new air flow meter costed me 60 quid
gtigolfthree
« Reply #3 on: 21 August 2009, 16:10 »
Disconnect the wiring on the maf if it runs better its faulty and replace it.
Offline DAVEMARX
« Reply #4 on: 21 August 2009, 23:37 »
same as i had on my 95 8v..... dirty maf .... as said unplug it see what happens but you will loose about 10mpg like i did if you run it ...
just unscrew it and have a look.....if dirty spray with carb cleaner.
Dave
