Author Topic: Intake air temp sensor?????????  (Read 1244 times)
Offline dannyboy2501
  • Blackberry IM pin 228D8231
« on: 01 August 2009, 13:10 »
Ello again
i own a mk3 golf gti 16v a mate of mine plugged
his diagnostics machine in my motor and it came up with the
following -
1) manifold pressure sensor
2) throttle posistion sensor (Done)
3) intake air temp senor ?????? aint got a clue where this is LOL
so all advice welcome maybe pics aswell many thank you all
and all so does any1 no of a link like this 1 http://www.golfgtiforum.co.uk/index.php?topic=101400.0
just in a 16v valve very cheeky i no LOL thanks again
« Last Edit: 01 August 2009, 13:15 by dannyboy2501 »
gtigolfthree
Re: Intake air temp sensor?????????
« Reply #1 on: 01 August 2009, 13:19 »
Its on the picture in your link close to the air box. Should be same on 16v.
« Last Edit: 01 August 2009, 13:22 by gtigolfthree »
« Reply #2 on: 01 August 2009, 13:23 »
yea seen that 1 be4 thanks
locin78
« Reply #3 on: 01 August 2009, 13:42 »
Hi Mate , right i had this prob with mine, the wires that go from the position sensor on the throtle body follow them they go behind engine they get cooked with the heat!! replace them which is prob causeing this reading!!!. what is the prob with your car?
Nic
« Reply #4 on: 01 August 2009, 13:45 »
Idleing problem using more fuel and getting hot really quickly.
locin78
« Reply #5 on: 01 August 2009, 13:50 »
on mine it was juddering between 3 and 4000 revs in the end  changed the fuel relay which solved the prob on mine take it for a run for a bout 5-10 mins and feel the fuel and ecu relay if thy are cold they are f?cked then replace them if they are warm then they will be fine. fuel relay is on top row 2ndor 3rd in from left and ecu is on the bottom far right.
Nic
