Author Topic: Smoking!  (Read 1804 times)
gtigolfthree
Re: Smoking!
« Reply #10 on: 01 August 2009, 19:01 »
If its not using water or mixing water with oil or performace/compression issues then probably not gasket
Offline shonza
Re: Smoking!
« Reply #11 on: 05 August 2009, 19:21 »
A strong smell could be a blocked breather hose or the block on top the cam cover.
Reference the smoking, sounds like oil is leaking down into the bores which suggest a valve guide or seal problem or could be a ring issue.
Might be a good idea to carry out a compression test as your next move.
Wayne, just checked and compression seems fine and no obvious oil use since the last service about 6 months ago.
Is it possible that a bloked breather pipe can be the cause of the smoke at startup??
Regards
VW BUSH
Re: Smoking!
« Reply #12 on: 05 August 2009, 20:43 »
Regards
Smoking on start up is oil in the combustion chamber caused by an internal leak. (seal gasket crack etc)
This leak may be very small and not a problem at the moment.
It might be the start of something serious, it will shag your cat though
My bet is valve stems if the compression is ok
