Author Topic: INFO Mk3 Engine Conversion FAQ (All questions and answers here)  (Read 230500 times)
Re: INFO Mk3 Engine Conversion FAQ (All questions and answers here)
« Reply #60 on: 29 November 2011, 23:29 »
This question is getting asked lots these days so worth bumping this I think. :smiley:
Offline rmas
« Reply #61 on: 10 January 2012, 12:45 »
Hi guys, i just did my swap from a ABU to a AGG this weekend, but now i have a problem with the drive shafts. The ones from the ABU engine have the flange in the gearbox measuring 90mm and the AGG gearbox is 100mm. How can i solve this, does anyone know?
Offline rmas
« Reply #62 on: 16 January 2012, 11:27 »
Problem sorted... Just got the transmissions from a diesel one :)
Offline popleyruss
« Reply #63 on: 28 January 2012, 14:54 »
Just in bolt the flanges and swap them over
Just plain dubbin
Offline rmas
« Reply #64 on: 01 February 2012, 11:30 »
Not that easy :( My old gearbox was a 085 and the the GTI one is a 020 so the flanges are totally diferent and cannot be swapped. If that is what you were refering off course...
Offline Dan_GTi8v
« Reply #65 on: 02 February 2012, 07:35 »
isnt an 085 a polo gearbox?
Offline popleyruss
« Reply #66 on: 02 February 2012, 08:12 »
Be never used an o85 no and if it's the polo gti one there made of chocolate
Just plain dubbin
Offline rmas
« Reply #67 on: 02 February 2012, 09:07 »
It comes in a lot of cars, Golf, Vento, Polo G40 also i think.
Offline Diluxe
« Reply #68 on: 15 November 2012, 14:02 »
when doing a 16v to r32 conversion, is it the clocks that needs changing or the signal sender that plugs into the g-box for the revcounter to work correctly?
cheers
1997 16V
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #69 on: 19 November 2012, 18:46 »
you will need to swap the clocks to VR6 items pal
Not no ordinary GTI....
www.mixcloud.com/kells/
