Author Topic: Car creaks when i turn right!!  (Read 1203 times)
locin78
« on: 29 July 2009, 22:38 »
Hi , when i drive my car it creaks only when i turn right , i did think it was my wish bone as it did need replacing but it still does it now and then since replacing the wishbone any ideas??
Nic
Offline boneybradley
  • Back in a Mk3...
Re: Car creaks when i turn right!!
« Reply #1 on: 29 July 2009, 22:41 »
mine creaked and it was the hub (after 2 bearings in 6000 miles!) worth checking as the bearing was tight
Offline Reasty
  • Alpine white valver.
« Reply #2 on: 29 July 2009, 22:43 »
My moneys on one of the ball joints,mine did this and thats what it was,jack the car up and check them if they are knackered the rubber seal will be split.
locin78
« Reply #3 on: 29 July 2009, 22:44 »
Hi, i replaced the bearings at the same time i did the rear break disks it did it before and still does now and then! do you think it may be a shock????
Nic
locin78
« Reply #4 on: 29 July 2009, 22:46 »
i'll check as i only replaced one wishbone it well could .
thanks Nic
« Reply #5 on: 30 July 2009, 08:38 »
mine did this and it was the whole rack moving as the nuts had worked loose
