Author Topic: fault reader  (Read 2248 times)
Offline davetindall104
Re: fault reader
« Reply #10 on: 29 July 2009, 10:35 »
excellent, thanks for that
Big Help!
Re: fault reader
« Reply #11 on: 29 July 2009, 11:14 »
one more question...
is it easy to work?
Thanks
Dave
Offline ace
Re: fault reader
« Reply #12 on: 29 July 2009, 11:22 »
yeah simple, plug it in switch the car on and use the relevant buttons on the reader.
Offline gtiscott
Re: fault reader
« Reply #13 on: 29 July 2009, 11:39 »
is it specific, I.E does it tell you which abs sensor is not working(or give the code for it)
Offline ace
Re: fault reader
« Reply #14 on: 29 July 2009, 11:51 »
should do. the one ive got is slightly different to this one, but i got a book of all the codes in it.
Offline alien.46.uk
Re: fault reader
« Reply #15 on: 29 July 2009, 12:00 »
It'll give specific codes if the car is designed to do so. The codes it reads are already being seen by your ECU, this reader basically pulls those errors codes from the ECU for you to see.
It powered by your car, so as soon as you plug it in, ignition or not, it'll turn on then search through the Codecs to find which your car uses. Then it'll scan.
Not sure those units come with general errors codes, but some cars can have manufacturer specific ones which just require a google hunt useually.
Offline gtiscott
Re: fault reader
« Reply #16 on: 30 July 2009, 09:16 »
just got this and it works great.....showed up the usuall abs speed sensor code :cry:
