Author Topic: Fitting plus suspension to 4 stud car.  (Read 1147 times)
Offline tomstickland
« on: 27 July 2009, 21:20 »
From what I've read it looks like the GTi and VR6 got longer front arms, different ball joints, hub carriers, steering tie rods and the 5 stud hubs.
I've been looking into whether I can mix and match various parts, but I'm coming to the conclusion that I should either swap the entire plus set up over or modify the 4 stud set up.
I imagine that the only real handling benefits of the plus system are that it gives a wider track and more camber.
Offline boneybradley
  • Back in a Mk3...
Re: Fitting plus suspension to 4 stud car.
« Reply #1 on: 27 July 2009, 21:23 »
the gti/vr all have larger anti roll bars, stronger wishbones,uprated steering rack etc and you can't mix and match but you could fit the full set up (converting to 5 stud) check lazylunatics thread as he's gone from 4 to 5 stud
« Reply #2 on: 27 July 2009, 22:37 »
Thanks.
Yes, we just looked at the vagcat website and realised that the rack is different too.
Did they make any 5 stud steel wheels?
Trouble is I have to then convert the rear over and I've got an estate with drums on the rear. So then bias has to be sorted out.
« Reply #3 on: 28 July 2009, 08:53 »
Thanks.
Yes you can get 15" as fitted to GL's and 16"s from the new Beetle or some Seats.
« Reply #4 on: 28 July 2009, 23:05 »
OK, thanks.
Someone told me that it's possible to press the 4 stud hubs into the 5 stud carriers.
« Reply #5 on: 29 July 2009, 10:30 »
As said on cgti the 4 stud mk3 is widetrack already, pretty sure the wishbones are the same length.
The only difference with the rack is the gti one is quicker.
