Author Topic: changed Pads, now caliper touches inside of alloy  (Read 2584 times)
Offline harlemex
Re: changed Pads, now caliper touches inside of alloy
« Reply #10 on: 26 July 2009, 18:06 »
^^ what difference would that make? :huh:
Offline Mikester
  • Civic Type R
« Reply #11 on: 26 July 2009, 18:07 »
I didnt want to say this, but yeah. Exactly. It wont make no difference. lol.
Offline omex_uk
« Reply #12 on: 26 July 2009, 18:22 »
lol sorry i forgot that golfs have stationary calipers.
on my old car the calipers used to get pushed outwards ever so slightly. good old french cars
Offline boneybradley
  • Back in a Mk3...
« Reply #13 on: 26 July 2009, 19:10 »
I have already said "its because he's using mk4 rims which are narrower and have an offset of et42"....it makes a difference as when on std wheels the calipers are close to the wheel that et1 and half inch means they get snug (too snug sometimes)
Offline Mikester
  • Civic Type R
« Reply #14 on: 26 July 2009, 19:14 »
He is sorry for doubting your honor and moderator. lol.
Offline bored_Welsh_lad
« Reply #15 on: 27 July 2009, 06:43 »
who wouldnt doubt boney...hes dodgy as.. haha
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Ess_Three
« Reply #16 on: 27 July 2009, 08:29 »
You are correct...but the design of the rear of the spokes are different 7" ET43 to 6.5" ET42.
The offset shouldn't affect it, nor should the width, if the rest was the same...but they aren't.
The curve on the spokes is different between them.
But, as you say, that's the problem.
..but gaining motorcycles.
Offline cs98sss4
« Reply #17 on: 30 July 2009, 22:53 »
That is the problem- rub the pads down like people do when they end up with g60 pads trying to fit them to there 16v set ups- Gurds has had to do this to his ds2500 when they sent them in error and it was too close to track to do anything about it. use a belt sander
cheers
suk,aminder,karan,taks
Golf MK3 16V ABF "Anniversary"
