Author Topic: window motor help  (Read 1470 times)
Offline omex_uk
window motor help
« on: 25 July 2009, 22:50 »
right i replaced my motor with a new one and every thing works fine but it seems when i push the button for it to go up (yes its electric) it gets about half up stops and goes back down.
im guessing the windows are meant to do that to stop the motor burning out but ive had a look and there no obstructions or anything in the way.
any ideas or common faults i should be aware of?
Re: window motor help
« Reply #1 on: 25 July 2009, 23:17 »
Not 100% sure but it might need to be set.
Offline omex_uk
« Reply #2 on: 26 July 2009, 00:38 »
care to elaborate ? im not sure what that means
adamrob69
« Reply #3 on: 26 July 2009, 10:36 »
im prety sure the motor will always try and run. If your window is at the top and you press the close button it will still try and move it, you hear it clicking etc.
maybe it is something with the regulator?
Offline omex_uk
« Reply #4 on: 26 July 2009, 19:00 »
cheers mate any ideas where the regulator is? never really played with windows before
Offline VR6_Wherry
« Reply #5 on: 27 July 2009, 10:28 »
My suggestion would be to take the window back out and re fit it. It could be an allignment issue. They usually go back down when theres something in the way (on the later models) The motor on mine went and i had to refit it and had to allign it a few times so it would sit properly.
Hope this helps!!
Offline omex_uk
« Reply #6 on: 27 July 2009, 10:46 »
Hope this helps!!
cheers mate il give it a go at the weekend
