Author Topic: Water Leak  (Read 2779 times)
Offline buzzkip
Water Leak
« on: 25 July 2009, 19:54 »
Hi all!
I was wondering if someone could help me. I've discovered a leak where one of the pipes connects to a joint. Sorry I can't be more specific, I've only just got the car so I'm incredibly new to this.
I've got some pictures of where the leaks is.
Please help? I don't know what the part is called sorry
Changed username from "iAMarshall".
gtigolfthree
Re: Water Leak
« Reply #1 on: 25 July 2009, 20:03 »
Water pump.
Re: Water Leak
« Reply #2 on: 25 July 2009, 20:04 »
Water outlet, that is not the water pump which is a lot lower, you can get a new o-ring from VW.
Offline buzzkip
Re: Water Leak
« Reply #3 on: 25 July 2009, 20:08 »
It's not an o-ring job though, right?
It's leaking from the joint, not where the pipes are tightened  :undecided:
gtigolfthree
Re: Water Leak
« Reply #4 on: 25 July 2009, 20:15 »
Sorry just a guess.
Re: Water Leak
« Reply #5 on: 25 July 2009, 20:15 »
Where it bolts to the head is an o-ring.
Offline 1 gti
Re: Water Leak
« Reply #6 on: 25 July 2009, 20:31 »
I've just replaced this on my mk3. Take the car to VW or GSF and show them the part. It's only a water joint. It's not that expensive from main dealer. The O ring is built into the joint. Hope this helps
Re: Water Leak
« Reply #7 on: 25 July 2009, 20:32 »
Just for info you can get the o-ring on its own if needed.
Offline Khare
  • The bear that khares
Re: Water Leak
« Reply #8 on: 25 July 2009, 20:38 »
go gsf and ask for cylinder head front water outlet.
iirc its about 7 pounds or something and takes 2 minutes to swap over.  :smiley:
Water pump.
Sorry just a guess.
Well its the most stupid guess i've heard. Dont just randomly guess if you are clueless!
Offline buzzkip
Re: Water Leak
« Reply #9 on: 25 July 2009, 20:44 »
Thank you all!
So it this safe to drive around? It's not spraying out, it hisses like a quiet steam engine idle  :shocked:
Also, what's the safe period of time to wait until you can open the water reservoir to check the water level?
Thanks!!!
« Last Edit: 25 July 2009, 21:01 by iAMarshall »
