Author Topic: Vr6 Tuning  (Read 9751 times)
Offline AudiA8Quattro
Re: Vr6 Tuning
« Reply #20 on: 26 July 2009, 14:38 »
Just my 2p's worth - any VR6 will need a small refinery to fuel it, especially if you like the loud pedal  :evil:
A heavily tuned 16v will also drink fuel  :rolleyes:
If a 16v and a vr had the same bhp the vr will always drink more fuel.
Not necessarily. A tuned up 16v which matches the standard vr will probably be just as thirsty.
I was pointing out that any heavily tuned engine will drink fuel.
« Last Edit: 26 July 2009, 14:40 by AudiA8Quattro »
Re: Vr6 Tuning
« Reply #21 on: 26 July 2009, 15:18 »
Not really, the VR has a lot more torque so will sit in higher gears whilst the 16V will be screaming along, don't think their will be much in it to be honest.
Re: Vr6 Tuning
« Reply #22 on: 26 July 2009, 15:48 »
Also, to add, state of tune has alot to do with fuel consumption.
Engines are set up to run close to lambda, or in other words perfect fuel/air mixture.
This however can be set 10% either way of lambda from factory. I most cases from factory, engines can be set on the lean side, to keep fuel consumption and emissions down.
A re-map will obviously change this.
Other factors will affect fuel consumption, how well the engine 'flows' ie. filter and exhaust, and longer duration cams.
Bigger capacity does usually mean more fuel consumed. but its not always the case.
