Author Topic: Advice....  (Read 7087 times)
Offline jonesltd
  • MK7 R
Advice....
« on: 23 July 2009, 13:40 »
Got a fli amp and sub all in 1 with a kenwood stereo...want better sound than what I have got mainly cos certain r'n'b tracks it sounds likes it blowing...any advice? Got a mk4
If you cant find it......Grind it
Offline Red_Tekk
Re: Advice....
« Reply #1 on: 23 July 2009, 14:37 »
Are you talking about upgrading what you've currently got or adding more to the system?!
Are you happy with your current HU, Amp, Sub performance...?
What do you mean by blowing?! Distorting?!
Offline B-chi
Re: Advice....
« Reply #2 on: 29 July 2009, 11:34 »
Sounds like the settings on the hu or amp might be wrong.
Do you have bass boost on the amp on?
Do you have the bass up on your hu?
Do you have loud on?
Do you know how to set the gain on your amp!
What's your amp crossed over at?
Is it the sub or speakers that are distorting?
Offline jonesltd
  • MK7 R
Re: Advice....
« Reply #3 on: 04 August 2009, 19:46 »
Sorry for delay...dont know how to set the gain on my amp...
http://cgi.ebay.co.uk/FLI-Trap-12-Active-Enclosure-Amplifier-already-fitted_W0QQitemZ260447696594QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Speakers_PP?hash=item3ca3e476d2&_trksid=p3286.c0.m14
Thats mine but not actually mine if ya get me!
I have put everything to 45 degrees so all level and when I do play lets say a gansta solider boy song or 50cent sometimes I believe the speaker mite zzzz, if it was the amp it would sound louder??? Can only really put it to volume 20 otherwise it can sound tinny. Altered it on stereo to pretty much near damit...
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Advice....
« Reply #4 on: 12 August 2009, 16:43 »
Well the Fli sub you got aint built to last long so chuck the old duffer and spend a little more money on something decent. Then personally i'd recommend changng the HU because that is the source of all your speaker/sub outputs, so if you've got a crappy HU, then in theory the sound coming out it will be wack also!
Worth a think maybe.
Offline B-chi
Re: Advice....
« Reply #5 on: 14 August 2009, 17:47 »
Setting up your gains/amp/hu.
First thing thing all audio controls need to be on there lowest setting.
On HU. Turn off loudness, bass/mid/treble on 0.
Looking at your amp (or similiar)
Turn your Gain down all the way to the left.
Next, Bass boost completely off
Now the Freq is dependant on a few other things but for the moment turn it to the middle.
Turn your HU up as loud as it goes without distortion on the standard speakers.
Now turn up the amp until you hear it distort then back it off a bit so it doesn't distort.
This is only a rough idea on how to set up your system.
If your system isn't loud enough set up like this, then it just isn't powerful enough.
Offline jonesltd
  • MK7 R
Re: Advice....
« Reply #6 on: 17 August 2009, 19:00 »
any ideas on how to test to see if mine has died? Having done ur advice which was excellent have a minor problem...fuse aint blown but no lights on the back of the box :cry:
Offline B-chi
Re: Advice....
« Reply #7 on: 20 August 2009, 23:21 »
When you turn the HU on the amp light doesn't!
could be a couple of things. The remote is not telling the amp to turn on or there is no power getting to the amp from the battery.
Check your power cable. You want good connections on both batt & amp, make sure there is no breaks in the cable also & double check your fuse. Wouldn't hurt to put another in.
Check your remote also. Again make sure there both terminated well & that there is no breaks in the cable.
Some HUs have the ability to turn the amp on/off in a menu!
Ideally you want a voltmeter to see what is/isn't getting 12v.
Offline jonesltd
  • MK7 R
Re: Advice....
« Reply #8 on: 23 August 2009, 16:11 »
Thank you...have checked the stereo kenwood kdc-w7031 and checked aint turned amp on or off and whatever setting I use then amp light still wont turn on regardless.
When I had the amp fitted it was fine, mate ages ago did something to me stereo and had to have it looked at and guy sed something to do with earth wire? Anyway ever since it was fixed it does a popping sound when I connect the HU, but now no longer popping hence I knew something was up and no light either.
Will buy a volt checker cos at min am runnin round with no boom boom.
Can you recommend any better head units to w7031 which I got? Want a more cinema sound? full sound as sitting in other cars they have a full intense sound compared to my flatish sound which I thought was good until I sat in other cars  :angry:
Offline B-chi
Re: Advice....
« Reply #9 on: 24 August 2009, 08:24 »
What do you mean by fuller sound?
You want to hear more freq range?
Louder bass?
Clearer front end?
If speakers pop when amp turns off sounds like the amp is bust mate. I had that with mine & it's being fixed. Think it's something to do with the ground.
Hu's. I like alpine sound, but units like pioneer p77 are good. Old school but packed full of features.
