Author Topic: Front & Rear Fogs don't work (with pic)  (Read 1601 times)
Offline jezza16v
Re: Front & Rear Fogs don't work (with pic)
« Reply #10 on: 24 July 2009, 15:06 »
OK, so its legal with just the one fog on a '91H? Thats the main thing as the mot is due shortly.
I'll have a play with the front fogs and let you know how I get on, they're not so important at the moment. Had this prob on my 16v back in 2006, tripped over my own post in a search, can only be a wiring/connection problem I'm sure.  :smiley:
« Reply #11 on: 24 July 2009, 15:30 »
yeah perfectly legal. as for fronts check you have a fog relay fitted, without one they wont do owt :)
Offline jezza16v
« Reply #12 on: 24 July 2009, 15:41 »
I'm presuming relay #10 (type23) is the one, there's a type23 in #11 as well, tried swapping over but no change.
I love Mk2's, there's always something to be fixed  :laugh:
« Reply #13 on: 24 July 2009, 16:03 »
yeah type '53' in slot 10 is the fog relay :)
worth checking the bulbs havent blown too, and check the fog loom is plugged in under the header tank (yellow/white and brown wires to a 2 pin plug)
Offline jezza16v
« Reply #14 on: 24 July 2009, 20:05 »
Yay! Front fogs work, slight corrosion film on bulb earth plate on o/s, corrosion on connector n/s...sorted!  :grin:
Checked rear fogs, no supply wire to the connector on the left, but no sign of plastic broken out, I note these clusters are the smoked ones off a 16v, perhaps the 16v have twin fogs........? I can see its easy enough to get a live to the LHS, but prob won't bother if its as it should be.
« Reply #15 on: 27 July 2009, 08:33 »
no MK2 ever got twin rear fogs from the factory, just got one on the left side for LHD cars, or one on the right for a RHD car ;)
