Author Topic: Brake upgrade  (Read 1595 times)
Offline MK3TDi1996
Brake upgrade
« on: 22 July 2009, 13:54 »
Hi everybody! (hi dr nick!)
I know this has already covered but before you either remove or critisize, I can't find out what I need to know!
I need to know what I can fit to my vehicle (1996 1.9TDi 90bhp AHU) in terms of disc/caliper/carrier upgrade - the other thing is i'm running on 14" alloys so am not sure what will actually fit without fouling the wheels....
Front brakes are those which i'm thinking of changing, the rear drums will do (unless there's something I can do there too?)
Thanks!
Offline christomk3gti
Re: Brake upgrade
« Reply #1 on: 22 July 2009, 15:21 »
This is a strange thread, as ive seen 288mm brake disks on a 1.4 R Reg Mk3.... (As Standard) Yes standard.
They are led to beleive that VW either had shortage of the smaller disks or had a massive stock of the 288mm disks.
That is why its a nightmare when buying disks and pads... You either have to measure them or bring one in.
So I would think, any of the mk3 disks would work, but some work may need doing???
Black 8v GTI............. Whats a Waffle Valve?
Offline MK3TDi1996
Re: Brake upgrade
« Reply #2 on: 22 July 2009, 16:28 »
Hmmm..... it's good to have the extra info but i'm still stuck ! lol :) thanks
VW BUSH
Re: Brake upgrade
« Reply #3 on: 22 July 2009, 16:33 »
What about Corrado discs up front, think they might go on MK3 4 stud
Might need 15" wheels, cant remeber if i ran em under my 14" P slots
Should be able to find something on the search button
Either that or go for full 5 stud 15" swap from GTI
Offline MK3TDi1996
Re: Brake upgrade
« Reply #4 on: 22 July 2009, 16:41 »
cba with the 5-stud jobbie - have searched and searched man, my eyes are going square! (should have listened to what my mother told me.... :p)
Offline Grim_Reaper
  • warningz...i haz powaz
Re: Brake upgrade
« Reply #5 on: 22 July 2009, 17:23 »
ive been told to use g60 (or was it g40???) brake calipers and disks, they were a direct fit apparently but now 100% dude...if i was sure then i would have done it :laugh: im tempted to see if my vaux 4 stud setup will fit because i cant find much on 4 stud brakes
Offline boneybradley
  • Back in a Mk3...
Re: Brake upgrade
« Reply #6 on: 22 July 2009, 18:20 »
you can use 256mm vented mk2 diss and pads using the o.e calipers but you'll need the carriers (and slimmer mk2 pads)
Offline LazyLunatic
  • MK3 20VT Project
Re: Brake upgrade
« Reply #7 on: 22 July 2009, 20:37 »
do what i have done. i posted this not long ago, lots of info around the forum, might be worth a search.
g60 brakes up front (mk2 16v hubs, mk3 gti 280 calipers/carriers, g60 discs, mk3 gti pads).
rear, keep your drums, unless you want discs, then you gotta get a mk3 gti rear beam and get some mk2 gti rear discs.
although not sure if you can run 280's under 14" wheels :undecided:
LL ;)
Offline MK3TDi1996
Re: Brake upgrade
« Reply #8 on: 22 July 2009, 21:41 »
LL ;)
awesome info :)- thanks! cept i now need to know if 280's will fit!
  • Back in a Mk3...
Re: Brake upgrade
« Reply #9 on: 22 July 2009, 23:04 »
280mm wont fit 14's....15 at least
