Author Topic: Help, my 8v is playing up !  (Read 953 times)
Offline STi
  • Jesus is coming...look busy !
« on: 21 July 2009, 08:43 »
Hello.
I digifant 8v is playing up big time !
It has been running fine, but when I tried to start it the other day it would not have it, when it did fire up it was running very rough and keep cutting out.
I managed to get home and by that time it would tick over but when I put my foot down it had a huge flat spot then it cut out.
I have tried the obvious, leads, plugs etc but to no avail.
Any help or advise would be great.
Sie.
Offline Tramp
Re: Help, my 8v is playing up !
« Reply #1 on: 21 July 2009, 09:26 »
It's a fuel issue by the sounds of it . Is the fuel pump OK?
I am sure there will be more wizards along too get into the thick of things.
« Reply #2 on: 21 July 2009, 09:30 »
Sounds fuel related.
« Reply #3 on: 21 July 2009, 10:28 »
check the lifter pump, pull the plug off the main pump under the car and turn the nkey 1 click, you should hear the in-tank pump prime. if not it is dead!
