Author Topic: ABS issues  (Read 898 times)
Offline Winso
ABS issues
« on: 19 July 2009, 12:52 »
I recently got the codes scanned and apparently I have faults on all 4 ABS speed sensors and on the ABS pump. If I remember right they were all intermittent though. How likely is it for all 4 sensors to go? Am I more likely to have some sort of fundamental wiring issue?
Offline Mikester
  • Civic Type R
Re: ABS issues
« Reply #1 on: 19 July 2009, 13:07 »
The sensors are likely to fail, and if you left it for a while i suppose they could all go. They dont get worn out so much from being used, its the fact they are exposed to the elements also that ruins them.
ianw3321
Re: ABS issues
« Reply #2 on: 19 July 2009, 13:15 »
Yes check each sensor across its two terminals with an ohmeter they should read just over 1000 ohms if not replace.
Offline Mikester
  • Civic Type R
Re: ABS issues
« Reply #3 on: 19 July 2009, 14:34 »
There is a thread here to check them:
http://www.golfgtiforum.co.uk/index.php?topic=57396.0
I have done this many times, even though i have a fault reader. I have replaced all of mine in the past 2 years. lol.
