Author Topic: Engine Bay  (Read 4389 times)
Offline pauld_88
Engine Bay
« on: 18 July 2009, 22:51 »
ok need the tips and tricks guys best products techniques and procedures for cleaning my engine bay want it looking mint again as at the moment it looks a bit rusty!
« Last Edit: 21 July 2009, 23:12 by Guy »
www.m25dubs.com
Golf Mk3 GTI 8v - sold
Audi a4 1.8t QUATTRO (B6)
Offline johnson6672
Re: Engine Bay
« Reply #1 on: 19 July 2009, 20:03 »
CD2 engine cleaner and detailing spray is good, they sell it in halfrords.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline jonesltd
  • MK7 R
Re: Engine Bay
« Reply #2 on: 20 July 2009, 08:55 »
ppl say WD40?
If you cant find it......Grind it
Offline Rhyso
Re: Engine Bay
« Reply #3 on: 20 July 2009, 09:20 »
i used Autoglym Engine & Machine cleaner and some detailing brushes
Spray liberally, taking care not to spray electrical stuff (some people cover it up), and then use the brushes to scrub the cleaner in
Then i used a pressure washer and rinsed off, making sure i didn't keep the hose directed at any one area for more than 1/2 second or so
i then allowed it to dry naturally and used some Poorboys Natural Look on the plastics
Offline Guy
Re: Engine Bay
« Reply #4 on: 20 July 2009, 17:37 »
i use a TFR /APC mix and a pressure washer... i top it off with a water based silicone spray so you can just spray it on and leave it to dry
you can use a AG engine machine cleaner or similar for the grubbier bits if you want... but unless you are showing the engine you could end up doing a lot of hard work when you don't really need to
wash the inside of you bonnet too... spray on the solution at the same time as you are doing the engine bay, then pressure wash before you rinse the engine bay down, if you have soundproofing material try not to let this get waterlogged as it could sag
Offline Dan J
Re: Engine Bay
« Reply #5 on: 21 July 2009, 00:49 »
soundproofing will sag for def whilst water logged but unless in really bad condition in the first place it should be ok,dont hold the lance too close to it and wires etc(as stated above)
get your engine nice and hot before you do this,makes it alot easier for the solution to break the crap down on the engine,make sure you make enough solution to keep re-applying to the bay to stop it drying out,leave for 5mins or so and wash off,
close bonnet and get engine hot again to dry the bay out, now hot and dry you can apply your chosen dressing,i use highstyle from autosmart.
Offline Guy
Re: Engine Bay
« Reply #6 on: 21 July 2009, 14:43 »
i've found finish is an excellent product for this... spray on and leave it... job done!  :wink:
Offline johnson6672
Re: Engine Bay
« Reply #7 on: 21 July 2009, 19:04 »
That CD2 stuff has a detailing spray and a cleaning spray, the detailer you just spray on and leave, wil try and find some pics of my scoobie when i used it, came up really well, did it for a show and had people asking me all day how i got it that clean.
Also used a pressure washer to remove the cleaner, worked a treat.
Offline Guy
Re: Engine Bay
« Reply #8 on: 21 July 2009, 23:18 »
cd2 iirc doesn't contain a degreaser, just some light cleanser
whatever product you end up using will probably contain a lot of silicone anyway
Offline Ninja
  • 19 smiles per gallon
Re: Engine Bay
« Reply #9 on: 22 July 2009, 23:50 »
Where can you get that cd2 from?
