Author Topic: speed clock removal?  (Read 2330 times)
Offline sharki786
  • GOT BOOST??
« on: 15 July 2009, 18:43 »
hi all,
right lads i need to know how to take the speed clock out on my mk3 gti its anniversary (1996) not sure if they the late style but might be old style. just want to do a LED mod but no1s helping me out & kells who did it aint here no more  :cry: ive sent him a pm but no luck you guys scared him of. but anyway need to know what type of LEDS i need ive looked and looked on here and googled it but no luck! the links on the guides to ebay dont work as they are old and bidding has ended (obviously) on them. will the 3mm 12v PREWIRED with resistors do the job or wont? just stuck realy want and NEED your help! and how many UV's do i need for the clock?
PLEASE PLEASE PLEASE HELP ME!!!  :cry: :cry:
Thanks in advance.
Sharki
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline MK3TDi1996
Re: speed clock removal?
« Reply #1 on: 15 July 2009, 18:50 »
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 15 July 2009, 18:53 »
been throught this my friend, need to know the the led type. says 3mm 12v led but they come with resistors that you have to solder on?? unless where they go (under the Display units) have 12v runnig throught it.
*****MK4 GTI T*****
Offline MK3TDi1996
« Reply #3 on: 15 July 2009, 18:55 »
is it the resistors you require? sorry if i'm confused.... - City Electrical Factors (CEF) or maplins will have those bits...
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 15 July 2009, 18:59 »
sorry mate ive tottaly confused myself AND you. ok you know on the clock when you take them out and remove the needles and all that then you have the display left where it shows you the miles mpg etc etc? then after you have un-soldered the displays of your left with the little smd leds? kells took them out and replaced them with 3mm blue leds, now this is what i want to know did he use a 12v resistor under ther or did he solder it just straight to the board without the resistor? thats what i need to know.
cheers mate
*****MK4 GTI T*****
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #5 on: 15 July 2009, 23:24 »
Richie 360 may know, he had his clocks done by brad i think.
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 16 July 2009, 12:12 »
ok spunky  :wink: il ask him cheerz mate  :smiley:
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 16 July 2009, 13:43 »
also for the window switches will 3mm 12v LED do? i got 3 colours in mind blue, red or purple? what do u think? purple is at the bottom of the list.
*****MK4 GTI T*****
Offline Adam
Down Hill From Here.
