Author Topic: will be fitting  (Read 3505 times)
Re: will be fitting
« Reply #10 on: 14 July 2009, 20:32 »
My fitting guide: http://www.golfgtiforum.co.uk/index.php?topic=68845.0 might come in handy.
errr thats BB's fitting guide... :huh:
No its not, scroll down and you will see my fitting guide.  :smug:
Offline shepgti
Re: will be fitting
« Reply #11 on: 14 July 2009, 20:46 »
i stand corrected says the man in the orthapedic shoes
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
Re: will be fitting
« Reply #12 on: 15 July 2009, 12:35 »
Change the top mounts rear and front. VR6 mounts for the front.
Remember to put the front bearing bellow the nut not ontop.
Take your time and remember to measure the thread on each side to ensure they are the same both sides.
The rear will sit higher than the fronts due to the added weight.
vr6 for the front, ordered them, what for the rear?
Re: will be fitting
« Reply #13 on: 15 July 2009, 12:37 »
These: http://cgi.ebay.co.uk/Set-of-4-VW-Golf-Mk2-Mk3-Vento-Corrado-Rear-Top-Mounts_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1689Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem5d255d19ddQQitemZ400058816989QQptZUKQ5fCarsPartsQ5fVehiclesQ5fCarPartsQ5fSMQQsalenotsupported
Offline tobybrennan
Re: will be fitting
« Reply #14 on: 15 July 2009, 12:48 »
perfect, thanks wayne
Re: will be fitting
« Reply #15 on: 15 July 2009, 12:56 »
No worries, I used them with no issues.
Offline tobybrennan
Re: will be fitting
« Reply #16 on: 15 July 2009, 13:13 »
whats wrong with the standards then:)
i obv took your advice, no questions and just brought them
but just out curiosity:)
Re: will be fitting
« Reply #17 on: 15 July 2009, 13:20 »
No difference really but your old ones will be really soft and can lead to rattles
Offline tobybrennan
Re: will be fitting
« Reply #18 on: 15 July 2009, 17:38 »
i've read somewhere a might need some sort of alignment after ive fitted the coilovers
whats this about?
Offline Adam
Re: will be fitting
« Reply #19 on: 15 July 2009, 18:04 »
Yea you need to get your camber re setup. If you don't it will handle like a pig and eat tyres.
Down Hill From Here.
