Author Topic: Fit a rebuilt engine or engine rebuild?  (Read 2211 times)
Offline danny_p
Re: Fit a rebuilt engine or engine rebuild?
« Reply #10 on: 14 July 2009, 23:17 »
i was bored  so
Part Number Description Fitment Price(£) Quantity Delete
16164A CRANKSH.THRUST WASHER SET G2 1.05 To 1.8 Carb & F.Inj All 6.50
16195 CON ROD BEARING SET-STD G2 1.8 GTI/GLI & 16V 8/82 > With Oil Hole 14.50
11533 ENG.GASKET SET-BOTTOM END G2 1.8 16V 7/85> 38.50
92631D IGNITION LEAD SET G2 16V 2/86 >10/91 34.15
17953R WATER FLANGE G2 GTI / 16V 8/83 > 4.00
02456 CON ROD BOLT G2 16V 2/86 >10/91 1.75
02470 CON ROD NUT G2 16V 2/86 >10/91 0.45
16152 MAIN BEARING SET-STD G2 1.05 To 1.8 Carb & F.Inj All With Oil Hole 21.60
16546 PISTON RING SET-81mm G2 1.8 Carb , GTI/GLI & 16V 8/83 > 31.50
17626 THERMOSTAT G2 16V 2/86 >10/91 4.85
92151 DISTRIBUTOR CAP G2 16V 8/86 >10/91 7.00
17058 WATER PUMP-COMPLETE G2 GTI / 16V 8/83 > 18.25
11640 DIPSTICK GUIDE G2 16V 2/86 >10/91 1.00
01200 CORE PLUG-ENG.BLOCK G2 All 0.70
15325 OIL PUMP G2 16V 2/86 >10/91 49.50
SB95013 SPARKPLUG-F6DTC G2 16V 2/86 >10/91 1.50
14537 CAM FOLLOWER-HYDRAULIC G2 8/85 > 7.60
17875 WATER PIPE-METAL G2 1.8 8v F.Inj 8/83 >10/91 17.50
15499 OIL COOLER G2 16V 2/86 >10/91 34.60
11638 SEAL-SUMP DRAIN PLUG G2 All 0.20
14486B VALVE GUIDE-36.5mm General Use. Various VW/Audi 1.8-2.8 95> inc. Diesel 2.70
11490 CYLINDER HEAD GASKET SET G2 16V 2/86 >10/91 42.75
01159 CYLINDER HEAD BOLT SET G2 1.8 16V 2/86 >10/91 17.20
18753 FUEL INJECTOR-PETROL G2 16V 2/86 >10/91 27.50
92218 IGNITION ROTOR ARM G2 16V 2/86 >10/91 4.25
17952 WATER FLANGE ON HEAD-SIDE G2 1.8 8v F.Inj (Not G60) 8/88 >10/91 6.45
15498 SEAL FOR OIL COOLER G2 16V 2/86 >10/91 1.75
MMW719/5 OIL FILTER-MANN G2 Petrol (Not G60) 8/83 >7/92 2.30
TOTAL(exc. VAT )£ 658.85
VAT £ 98.83
TOTAL £ 757.68
all the VW's have gone bar 1.
Offline simonfa
« Reply #11 on: 15 July 2009, 11:41 »
Thanks for the replies guys.
Although a bigger more powerfull 2.0 would be attractive i would like to keep my Valver as standard as pos, im not really into all that mod'ing and making cars bigger wider lower and faster, if that was what it was about i would have bought a faster car in the first place!
One of the reasons i wanna do the replace or rebuild is cos i have few slight issues i need to sort out any way, they are not major and the engine does run well, idles fine and pulls well but things like oil in the air filter and breather pipe, small rocker gasket leak, dizzzy oil seal seems to have a small leak and would just like to generally have a tidy up as its not the tidiest engine and bay in the world. Thought after the 18 years of running it has had i may be down a fair few horses so would have liked to get it back up to original figures and thought a rebuild would have done the trick.
Thanks for the list Danny_p  :smiley:
Offline danny_p
« Reply #12 on: 15 July 2009, 12:22 »
if thats the aim,  don't rebuild the motor but give it a good going over.
most of those are common niggels for a 16v  most of them arn't mialage related but more seals going off with age. have the injector cleaned or just replace them and take it to a rolling road and have it setup  i would expect it to up on factory specs
