Author Topic: deleting the headertank  (Read 3505 times)
Offline andc1
« on: 08 July 2009, 10:49 »
hi all, well im tyding up the engine bay, is there anyway to not use the horrible looking plastic header tank?
Re: deleting the headertank
« Reply #1 on: 08 July 2009, 11:11 »
I have seen a couple of people on ed38 fit a metal tube with a filler cap or you can switch to an earlier rad.
Offline ian007miles
« Reply #2 on: 08 July 2009, 16:31 »
allord motor sport do a alloy header tank to fit  mk1 golf
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline andc1
« Reply #3 on: 08 July 2009, 18:12 »
want to remove it complety not by an new one!
« Reply #4 on: 08 July 2009, 20:59 »
You will need to fit an early rad or a metal pipe with a filler cap.
Offline andc1
« Reply #5 on: 08 July 2009, 21:01 »
metal pipe with a filler cap?
« Reply #6 on: 09 July 2009, 10:15 »
search for 'inline filler cap' but id go for the early style radiator with cap built in, much neater. ive seen beemer rads used as well, these have a cap on and pretty beefy. cant remember the model off hand tho
Offline A7 UFO
« Reply #7 on: 09 July 2009, 14:19 »
I've just fitted a new top fill rad to my mk2.  Was only about £60 from GSF.
Offline andc1
« Reply #8 on: 09 July 2009, 15:23 »
so as long as i have something which allows me to top up i dont need it?
Offline SoundillusioN
« Reply #9 on: 09 July 2009, 15:32 »
That and an overflow near the filling point which most of these filler tubes and series 1 rads have.
