Author Topic: MK3 8v Wont start? HELP!  (Read 1031 times)
Offline Live in Hope
« on: 03 July 2009, 06:16 »
HI, just gone out to my motor and it does not even turn over? loads of battery power! everything working apart from when i turn the key nothining? fans lights all come on :undecided:
It's never missed a beat so far :sad:
Any ideas?
Offline Andy-H
Re: MK3 8v Wont start? HELP!
« Reply #1 on: 03 July 2009, 07:59 »
Seen a few posts like this before where one of the possible failings could be a faulty ignition switch  :undecided:
Have you checked all your fuses??
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
ianw3321
« Reply #2 on: 03 July 2009, 10:16 »
I am an auto electrician which is where you need to go as you cannot guess, have to do tests but chances are if battery is indeed ok, then probably the starter motor
Offline dr.gonzo
« Reply #3 on: 03 July 2009, 14:38 »
mines done this once or twice, do you have an imobiliser fitted? it may have triggered.
for me it was a case of locking the car, unlocking and then the imobiliser reset and it started no problem
ianw3321
« Reply #4 on: 03 July 2009, 15:58 »
If its immobiliser you wont get any ignition lights lock then unlock.
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #5 on: 03 July 2009, 16:43 »
Try "Lifting" your key as you turn it on the spring swith in the ignition barrell - it may be worn and not contacting properly.  :nerd:
Keeping schtum. Mostly.
« Reply #6 on: 03 July 2009, 17:34 »
Thanks for all the reply's!
AA man came out to car why i was at work and it started first time?  he is a family friend and gave it a good going over and found nothing?
Will have to see if it happens again, might be one of your suggestions above?
Once again thanks for your help :smiley:
Offline VW Mel
« Reply #7 on: 03 July 2009, 17:43 »
Hope it keeps going :smiley:
