Author Topic: Lowering debate  (Read 8251 times)
Re: Lowering debate
« Reply #50 on: 11 July 2009, 14:43 »
Major problem, i got all the bits from vw then come accross some major issues.
There seem to be two types of mounts, bearings etc.. on ETKA can anyone help?
The top spring plate changed from 60mm to 80mm I believe, but all the top mounts are the same.
Offline funkyfive
Re: Lowering debate
« Reply #51 on: 11 July 2009, 15:25 »
You sure its not 80mm to 60mm?
Re: Lowering debate
« Reply #52 on: 11 July 2009, 16:39 »
Yes sorry early ones were bigger.
Offline funkyfive
Re: Lowering debate
« Reply #53 on: 11 July 2009, 16:58 »
Damn that also means the top mounts will be different?
Re: Lowering debate
« Reply #54 on: 11 July 2009, 16:59 »
No all the top mounts are the same, you need VR6 spec.
Offline funkyfive
Re: Lowering debate
« Reply #57 on: 11 July 2009, 22:47 »
Problem i have got i am not over confident that the new spring plates will fit and hold the springs. Also the hole in the middle is alot bigger.
Offline funkyfive
Re: Lowering debate
« Reply #58 on: 12 July 2009, 08:32 »
As an idea could i use the old spring plates and put the new top mounts on? I've been told the strut housing is all the same on the mk3's!!??
Re: Lowering debate
« Reply #59 on: 12 July 2009, 09:52 »
Yes you can reuse the old spring plates.
