Author Topic: Lowering debate  (Read 8330 times)
Offline shepgti
Re: Lowering debate
« Reply #20 on: 05 July 2009, 00:05 »
Does anyone know where to get the socket from for the slotted nut for the top of the strut?
Or try a longish allen key and plug socket.
7mm brake caliper allen key works wonders
Offline funkyfive
Re: Lowering debate
« Reply #21 on: 05 July 2009, 07:14 »
I got the allen key, but not the socket for the slotted locking nut.
Offline funkyfive
Re: Lowering debate
« Reply #23 on: 05 July 2009, 09:27 »
Re: Lowering debate
« Reply #24 on: 05 July 2009, 09:30 »
http://forums.vwvortex.com/zerothread?id=1624489
I could not find a tool so I did mine as the above link.
Offline phatsam2003
  • mk4 1.8T
Re: Lowering debate
« Reply #25 on: 05 July 2009, 10:37 »
Was thinking of a complete suspension overhaul myself.
Correct me if I'm wrong but isn't it a complete b!tch to change it all? and is it possible to do it myself, or would I need some specialist tools?
Offline shepgti
Re: Lowering debate
« Reply #26 on: 05 July 2009, 10:59 »
is a piece of piss to do, only hard bit is fighting with rusty nuts/bolts..  i used a spark plug socket with an adjustable spanner attached to it wit a 7mm allen key down the middle instead of the slotted socket.
Offline phatsam2003
  • mk4 1.8T
Re: Lowering debate
« Reply #27 on: 05 July 2009, 13:40 »
Abso-bloody-marvelous!!
So changing all the bushes isn't hard to do? I thought I read before that they need to be pressed in/out and it's not an easy task....
Offline AudiA8Quattro
Re: Lowering debate
« Reply #28 on: 05 July 2009, 18:46 »
Aren't people getting confused between the top nut holding the plate and the slotted nut holding the top mount to the strut?
Offset spanner and allen key, or allen key and spark plug socket to do the top nut.
If i remember right the mk3 doesn't have the slotted nut, just a normal nut holding the strut together.
Well it did on the vr i had.
Re: Lowering debate
« Reply #29 on: 05 July 2009, 18:59 »
Correct, it is a normal nut.
