Author Topic: Got some mk1 Cabrio questions....  (Read 10005 times)
Offline gibby
Re: Got some mk1 Cabrio questions....
« Reply #10 on: 01 July 2009, 08:05 »
Are you sere it's a digi ? A 1.8 92 Sportline cab would usually be a k-jet.
I had a J reg Rivage and that was a k-jet DX engine. Have a look at the sticker in the boot that's on the bar for the leccy hood with the paint code etc. It should say the engine code there if I rememeber correctly. Also, I think it should give you the engine code on the V5, but I can't remember 100%.
......now officially dubless.
Offline 993turbo
  • Too many cars, too little time......
« Reply #11 on: 01 July 2009, 09:27 »
Thanks for your input.. :-)
Im not with the car, Im out traveling... Hence Me not being able to look up the engine code :-)
Further, the car is not UK reg, and subsequently does not have a V5..
Digifant vs. Jetronic...... I take it all Jetronic cars have a fuel distributor, with the assosiated fuel lines going to the injectors???? Mine simply has an air meter, and a fuel line going directly to Electronic injectors . I might be wrong, but I think think this means its a Digifant car, like my G60........... or...?
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline 993turbo
« Reply #12 on: 01 July 2009, 09:39 »
This is a K-jetronic engine, correct?? If so, mine is a digifant.
Offline gibby
« Reply #13 on: 01 July 2009, 11:40 »
I take it that's not your engine above then as that looks like a k-jet to me. If that is the case then you wont have a DX engine code. k-jets don't have an ECU as they are mechanical injection but the digi does.
Offline 993turbo
« Reply #14 on: 01 July 2009, 12:07 »
Yeah, for sure. Mine has an ECU. I take it its an 2H then....
Now, back to the org. question, what Engine mounts do I use.....?
Dinky
« Reply #15 on: 01 July 2009, 22:52 »
2h aye? it isn't a red cabriolet by any chance is it?
Dinx :kiss:
Offline 993turbo
« Reply #16 on: 02 July 2009, 08:15 »
Dinx :kiss:
Yeah, Red, why?
Dinky
« Reply #17 on: 02 July 2009, 19:22 »
Dinx :kiss:
Yeah, Red, why?
Because I only know of 1 other 2h engine in the uk other than mine and it belonged to a guy off the mk1 owners forum - can't remember his name but he was kind enough to copy his manual for these engines onto disc for me :smiley:
Unless you are actually in Marbella..then it may be a different one :grin:
Dinx :kiss:
« Last Edit: 02 July 2009, 19:24 by Dinx »
Offline 993turbo
« Reply #18 on: 03 July 2009, 09:02 »
Dinx :kiss:
Yeah, Red, why?
Dinx :kiss:
Im in Marbella, but the car is Red, with BBS, Recaros etc.... and a 2h engine......... :-) Are these rare??
Offline SoundillusioN
« Reply #19 on: 03 July 2009, 09:56 »
I dont think it's thats rare, VW did put the 2h engine on the cabs in later years for the US and European market.  In fact the cab has had quite a few variants in it's life.  What year is your car?  I found this which goes into a lot detail on this: http://www.cabby-info.com/engine.htm
