Author Topic: How To: Replace GTI High Level Brake Light WITHOUT REMOVING SPOILER  (Read 234171 times)
Offline Revcounter
 It worked great, thanks UB7RM for advice and pictures.
In my case and with my fat fingers I had to take a hacksaw to the tab of spoiler plastic to make the hole larger to get at the rubber grommet. (You can see the tab in the pictures),  that wasnt difficult.
  :nerd:
Offline billy_vw
Typical , My 3rd brake light is very dim , can hardly see it.  :sad:
I guess, i'd better give this a try too
MK5 GT TDi
Offline billy_vw
Ordred part yesterday & VW have just called to say its ready to collect  :smiley:
Lets hope i don't Fcuk this up now  :embarassed:
MK5 GT TDi
Offline billy_vw
All changed and now working.  :smiley:
Great guide
Many thanks
MK5 GT TDi
Offline Len
Looks good too! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline swenak
Hi all, I found this on another forum.
http://www.vw-club.cz/download/file.php?id=565257&mode=view
You can try it at your dealer.
Offline black5
Like many my High Level Brakelight was fecked.  It started with the LED's flickering then they all failed one by one until they were all goosed.
A visit to VW revealed the cost of replacing it was just shy of £400 (out of warranty  :sad:) and would involve removing the old spoiler (and in the process breaking it) spraying a new spoiler and remounting etc as the light was stupidly designed to be retained by a couple of screws INSIDE the spoiler.
With nothing to loose I decided to buy the lamp and have a go at removing the old one and refitting.
Thanks to Daywoo for giving me the confidence to have a bash at this, but I think his was a little easier to get out than mine as he had written in a different thread that his fell out of it own accord...
http://www.mk5golfgti.co.uk/forum/index.php?topic=5563.0
First step was to buy the replacement:
Part No. 1K6 945 097F - £35 ish
Image showing the back of the new light, flying lead and rubber grommit.
Next was the daunting bit - breaking out the old light.  For this I used some plastic trim removal tools I got of Ebay.  A good investment as it means the spoiler isn't butchered as you pry and lever the old one out.  That said there was a tiny amount of collateral damage to the housing but not too much.  But hey - you're saving £360  :smiley:
I started at the rear edge of the light and broke the light lens out.  No real technique - its pretty fragile and just a case of brute force and nasty noises.  Watch out for flying splinters!
Poor quality but there is a small gap just big enough to get a wedge in and start breaking the lens out.
Camera pointing up - photo of the bottom of the lens being broken out
Trim tool being used to break the lens out
Gunged up bit of lens - water has clearly been sitting there for a long time.
(Note I took my drill out as a way of breaking into the lens if needs be - I didn't actually have to use it.)
Lens all broken out - LED strip exposed.
Use a wedge / trim removal tool to pop the LED strip out.  I didn't take a photo of this but the wiring where it connects to the PCB at the back was corroded as expected.
With the LED strip pulled out its really just a matter of getting hold of the black housing and ripping it out.  I used a trim tool to lever the housing down in the middle and then grabbed hold of it and pulled.
Note the metal bit to the left, thats where the retaining screw goes into.  One on each side.  The plastic housing is quite weak and flexible so it will rip around the retaining bolts and come out as shown.
Once free of the light housing, the retaining screws will lift out of those slots and be discarded.
Again sorry for the quality but this shows where the plastic housing has ripped around the bolt.
Follow the cable up and you will be able to feel the rubber grommit in place.  I suspect it helps if you do this on a warm day like I did but its relatively easy to grab hold of this with your fingers and then use needle nosed pliers to pull it out.  Also helps if you have girly fingers!
Once you pull this out, the connector comes with it and it connects to another connector.  There will be just enough slack to be able to pull this out to just beyond the spoiler.  It looks pretty fragile so be carefull with this.  Undo the retaining clip and replace with the new one.  (Sorry got a bit carried away and didn't take a picture of the 'car side' connector.)
Picture of the 'light side' connector.
Push the wiring back in and push the grommit back into the hole.  This is a bit fiddly and is probably the hardest part as you cant see what you are doing.  You have go by feel alone.
Push the cable into the spoiler and snap the new light into place.  JOB DONE.
I didn't use anything other than the clips to hold the new light in place and it seems pretty solid.  If you wanted you could use some adhesive on the top to hold it in place.
Picture of the mangled old light unit.
Took me no more than 40 minutes.  Could probably do it again in about 20.
I did disturb the paint ever so slightly around the lip where the light unit sits but this is pretty much invisible unless you go looking for it and I will smooth it down with some wet and dry.
Just remembered I need to go out and re-aim my washer nozzle to 2 O'Clock so this never happen again....
Pretty chuffed with the result, and if I can do it, anyone can (but at your own risk  :wink:).  :cool:
Offline black5
Hi you all. just to say THANKS to all who cotributed to this. I replaced mine today and I only managed to do it in twenty minutes. I am quite handy with most diy. But again thanks for the great pictures which made the job very straight forward. Keep up the good work Pete
Offline KEITH66
Thanks for the excellent write up i found that if u drill the plastic casing first u don't scratch any of the paintwork! Only took me 20 mins max saving an absolute fortune!!!  :smiley:
Offline Kirkbyman
Hi,Thanks for the info.Changed mine at the weekend with no real problems
Chas
