The garage
can you sovle my idle problem?
Topic: can you sovle my idle problem? (Read 1302 times)
tweed
Forum addict
24 June 2009, 17:35 »
I post this here too.
http://www.golfgtiforum.co.uk/index.php?topic=120805.0
I'm getting my master cylinder tomo and then hopefuly getting a mot if all is sorted.
Thanks guys
Untitled
by
tweedub
, on Flickr
Paul86S2
Re: can you sovle my idle problem?
24 June 2009, 18:05 »
What did you do with the vacuum pipe from the throttle body to the airbox?
You really need to block this off. If it is left open it will cause a high idle like you describe.
Paul
tweed
Forum addict
24 June 2009, 22:34 »
I pluged it back in. I did take it back out when the engine was running and the revs went even higher.
Untitled
by
tweedub
, on Flickr
The garage
