Author Topic: Mk4 GTi 1.8 20V Snapped Cambelt - What do I do?  (Read 6559 times)
Offline MK4GtiMan
« on: 22 June 2009, 18:26 »
Hi All - I hope you can offer me some advice for a very sad Gti Driver.  I've only had her since march and she's been fine however, the oil light has been coming on and off for a little while even though there's plenty of oil in the motor.  I thought initially the sensor was playing up so I did not pay too much attention - Mistake No 1!!
I was on the motorway yesterday and suddenly lost power (would not go above 60mph) and the turbo was silent but the motor was still working.  After few more miles the car just cut out, no serious noises but simple refused to start.
I called the men in yellow and he rekoned the cam belt has snapped maybe due to low oil pressure??
My question is two fold:
1: Do you think he's right?
2: Do I rebuild the orginal engine, get a scrap engine or cut my losses!!
I'd appreciate your advice.
Steve
Offline DarkGti
Re: Mk4 GTi 1.8 20V Snapped Cambelt - What do I do?
« Reply #1 on: 22 June 2009, 18:31 »
**edit :grin:** why dont you just check see if the cambelt has snapped there is a plastic cover on the left side of the block just take it off and see if there is a cambelt there or if there is see if its loose! could also be a turbo problem!
« Last Edit: 22 June 2009, 18:34 by DarkGti »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 22 June 2009, 18:46 »
I'd like to know how exactly low oil pressure could snap a cam belt...
Does the engine sound ok when you tried to start it? If the cam belt was snapped you'd only be turning the bottom end over (and beating your valves) so I doub't you'd have any compression so it would sound totally different on the key
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 22 June 2009, 18:58 »
Sorry to hear of your woes, fella. :(
On the plus side, though................................  Time for a BAM upgrade!! 8)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline dai-cymru
  • 1989 MK2 16V
« Reply #4 on: 22 June 2009, 19:28 »
as wazzer said spin it over if its like a higher pitch noise than normal the belt is snapped i cant quite see how loq oil pressure would affect the timing belt unless the engine has seized  :undecided:
« Last Edit: 22 June 2009, 20:01 by dai-cymru »
jamie16v
« Reply #5 on: 22 June 2009, 19:44 »
are these classed as safe engines or what or is it a case of bent valves and smashed pistons time?..
Offline mikemk4gti
« Reply #6 on: 22 June 2009, 20:18 »
Yeah, I'd say that if the turbo has gone, burnt all your oil then seized the engine the belt may have gone. as said above take the top cover off the cambelt and have a look, also check the turbo.
If this has happened it would probably be cheaper to stick another engine in it.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 22 June 2009, 20:36 »
no not safe engines mate, it will smash the valves if it has :sad:
Offline MK4GtiMan
« Reply #8 on: 22 June 2009, 21:03 »
Cheers Guys - As you can tell I know F*** All - It's quite high pitched when I turn it over but no knocking or anything.  I notived earlier I could hear the tapets - The AA bloke mentioned if the oil pressure was low it could cause a valve to stick and put too much pressure on the cam belt?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 22 June 2009, 21:07 »
TBH it sounds like he is giving you worst case and strange scenarios on what has happened. Best bet is to pop the cover off and have a look for the belt, at least you'll know where to start.
