Author Topic: Rocker cover gasket change  (Read 2315 times)
Offline robz
Re: Rocker cover gasket change
« Reply #10 on: 22 June 2009, 16:10 »
ahh, with ya, lol
well europarts have got it down as rocker gasket so there, lol  :tongue:
is this the right one im orderng then, you've put doubt in my mind lol :)
cheers mate
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1993/p/Car-Parts/Engine-Parts/Engine-Parts/Gaskets-and-Seals/?368440330&1&3d2df989dd4069ea71cf141014ec328b6e577f4a
Offline Mikester
  • Civic Type R
« Reply #11 on: 22 June 2009, 16:38 »
Done this today.
Took about 20mins from undoing the first bolt to putting the last one back on.
Basically the hardest part is getting the 2 bolts on the back left in, as the coolant hoses, and throttle body gets in the way.
But other than that, not to hard at all. Turns out mine wasnt leaking, but just 2 of the bolts were VERY loose. Either way, all fixed.
Only other problem i found was i only had 1 cam. lol
Offline robz
« Reply #12 on: 22 June 2009, 16:41 »
cool - did you torque them down, or just ft (f*****g tight), lol :)
also is yours a 2e? -
are there any vac pipes running down the back of the rocker gasket??
Offline Mikester
  • Civic Type R
« Reply #13 on: 22 June 2009, 16:46 »
Mines an AGG. And there is vac pipes on the rocker cover coming down, that need to be removed. Also you need to remove the brackets to the throttle body on the rear of the cover. You would also benifit from removing the induction pipe for a bit more room. There is also coolant pipes that run along the back of the cover.
Its a bit fidly. And i didnt torque them up, as i dont have a torque wrench. But they were not that tight originally, and my car has ran fine, on the button for 3 years, never broken down. So im sure its an improvement. lol
Offline robz
« Reply #14 on: 22 June 2009, 16:56 »
ok, no worries m8, thanks for the info!!
will see what i can see on wed.
my car just does not wanna run right, if this fails im gonna have to get my vagcom working... thats a task in itself, lol
cheers :)
