Author Topic: hottuning coilovers mk4  (Read 4673 times)
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
Re: hottuning coilovers mk4
« Reply #10 on: 13 June 2009, 19:34 »
thanx for the reply on this as i was getting worried with the nagatives....
now drivin a golf 1.9 tdi 90bhp ... time to rack up them miles!! as my daily
Offline DarkGti
« Reply #11 on: 17 June 2009, 13:25 »
also got them fitted to mine, ride is sound and fitted perfectly apart from if you have big profile wheels like 225/40/18 and drop it to a certain amount the wheel will rub on the coilover adjuster!
Offline chrisj
« Reply #12 on: 17 June 2009, 13:29 »
I've got these on mine. only fitted them monday.see my thread in the mk4 section. Really happy with the ride to be honest. not too harsh or anything.
R Tech stage 1 AUM, Pipercross panel filter, forge 007p, Santa Monica's,Lowered 35mm Jamex Shocks and springs, Milltek Exhaust, mk5 rear wiper
Offline gjroe78
« Reply #13 on: 17 June 2009, 16:01 »
Had mine on the mk4 for 4 months now and had been really pleased with them for the money, pretty firm ride but thats what i wanted but as far as fitting them the garage i use had no problems at all(apart from lowering the front end too much(sorted now though))
Offline troublestarter
« Reply #14 on: 17 June 2009, 16:24 »
i have them on my mk4 and find they are more comfortable than the 35mm shock and springs i had originally
i did however remove the helper springs from the front as my A8 replicas have a 38mm offset and the tyres(225/40/18) caught on the springs
took them off car drives fine
i have also removed the rear adjusters
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
« Reply #15 on: 17 June 2009, 21:00 »
they turned up today and i have gota say they look really good for the £££ just hope they go on easy. also do they come set at a hight or do u have to just keep adjustin them .... if you do wots the best way to get the hight rite. was hopein for about 50mm back and 40mm front ... wot are you running them on
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #16 on: 17 June 2009, 21:10 »
Id set them 1/2 way down before you fit them then you can go either way to get the desired height.  :wink:
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
« Reply #17 on: 17 June 2009, 21:13 »
cheers :wink:
Offline gjroe78
« Reply #18 on: 18 June 2009, 08:57 »
I think you may struggle dropping them that much on 18's mate ? They catch or summet, and the rebound on them would be a nightmare
Offline tweed
« Reply #19 on: 18 June 2009, 10:02 »
I would rather go 50mm front and 40mm back.
