Author Topic: got the full version VAG COM!!!!!!!!  (Read 6228 times)
Offline navmk4gti
Re: got the full version VAG COM!!!!!!!!
« Reply #20 on: 11 June 2009, 15:28 »
ok kool thanks rhyso... ill give that a shot now  :smiley:
im going to put on unlock and lock horn sounds ...  :cool:
Offline kevin31
« Reply #21 on: 11 June 2009, 15:34 »
Is it easy enough to do then?
Can you change it to auto lock after a period of time? Say you walk away from car and forget to lock it have it lock after 30 secs?
Kev
1999 Golf GTI MkIV 1.8T 20V AGU
Offline Rhyso
« Reply #22 on: 11 June 2009, 15:37 »
Kev
no you can't do that
only time it relocks itself is if you unlock the car and then don't open the doors or boot.  It will relock after approx 30 seconds
Offline navmk4gti
« Reply #23 on: 11 June 2009, 17:18 »
i just did all the unlock and horn sounds.. the beep when you lock and unlock car is awesome  :shocked: sounds like you got a cobra alarm beep on the car  :cool: ... im well chuffed with it  :cool:
i tried doing the beep on my mates leon and it came out farty  :laugh:
Stevo-Anni
« Reply #24 on: 11 June 2009, 17:19 »
could i use my vagtacho cable with vagcom?
Offline Steve_PD
« Reply #25 on: 11 June 2009, 17:21 »
I dont think so
Offline navmk4gti
« Reply #26 on: 11 June 2009, 17:25 »
i dont think you can either as VAG tacho reads a complete different software doesnt it?? as the VAG COM is for reading fault codes and accessing your control modules  :smiley:
what area you from mate id love to use your VAG Tacho cable as a thank you for my email lol  :evil:
Stevo-Anni
« Reply #27 on: 11 June 2009, 19:37 »
i'm in blackpool mate if your ever by this way you can use it if you want mate
Offline navmk4gti
« Reply #28 on: 11 June 2009, 19:40 »
hmmm yh i may be poppin around in august sumtym .. ill drop you a pm nearer the time if i choose to come... i just need miles to empty now  :smiley:
Offline Rhyso
« Reply #29 on: 12 June 2009, 07:50 »
on an AGU - unlikey as it will be fitted with an Immob 2 clocks.
