Golf mk3
hardmonkeys
Emmisions Fail!
4
5
Topic: Emmisions Fail! (Read 4985 times)
AudiA8Quattro
Forum addict
Re: Emmisions Fail!
Reply #40 on:
12 June 2009, 23:55 »
I would change the lambda probe too.
If the cat is only a couple of years old, like you said, then something has f**ked it.
The probe is probably the likely cause.
Len
10k hero
Re: Emmisions Fail!
Reply #41 on:
13 June 2009, 17:40 »
Possibly, but surely if the engine is running correctly as proved by the combustion colours on the plugs then the oxygen sensor must be doing its job?
Isnt it only there to change the air/fuel mixture as its before the CAT.
www.sas.org.uk
www.the-ace.org.uk
Len
10k hero
Re: Emmisions Fail!
Reply #42 on:
14 June 2009, 16:15 »
Ummmmm been tinkering today with that crankcase breather and checking the dizzy cap fully and well I noticed a warning note on the cross beam by the bonnet catch! This says - Waring! overfilling with oil will damage the CAT!
:embarassed:
ooooops!
I have done that a few times!
Not by a great deal but could give an inkling why that crankcase breather burst! Hmmmmmm
www.sas.org.uk
www.the-ace.org.uk
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Re: Emmisions Fail!
Reply #43 on:
14 June 2009, 17:32 »
Sounds like your problem them matey. A lot of people don't realise that an over oil filled engine can be just as detrimental to it's health as a dry running one due to the extra oil pressure build up.
Len
10k hero
Re: Emmisions Fail!
Reply #44 on:
14 June 2009, 17:43 »
Well have managed to get the CAT off after busting a bolt and by using loads of WD40!
Looks very black in there!
www.sas.org.uk
www.the-ace.org.uk
thai-wronghorse
Re: Emmisions Fail!
Reply #45 on:
14 June 2009, 17:45 »
Black as in cooked oil?
Len
10k hero
Re: Emmisions Fail!
Reply #46 on:
15 June 2009, 16:36 »
Yes!
www.sas.org.uk
www.the-ace.org.uk
thai-wronghorse
Re: Emmisions Fail!
Reply #47 on:
15 June 2009, 22:09 »
Oops!
Khare
The bear that khares
Re: Emmisions Fail!
Reply #48 on:
15 June 2009, 22:38 »
well it will be black! its were most of the soot from the engine goes!!!!
Len
10k hero
Re: Emmisions Fail!
Reply #49 on:
17 June 2009, 10:38 »
Sticky black!
Anyway all is good now!
Had codes read and no faults AND its passed its MOT.
So was the CAT!
Emissions test also showed that lambda maybe a little suspect too! Marginally over!
So Nick/Ben (RTech) was nowt to do with the remap! Realised that after checking the plugs and thinking sensibly instead of in a panic!
www.sas.org.uk
www.the-ace.org.uk
4
5
Golf mk3
hardmonkeys
Emmisions Fail!
