Author Topic: Emmisions Fail!  (Read 5009 times)
Offline Paul86S2
Re: Emmisions Fail!
« Reply #10 on: 10 June 2009, 14:51 »
Len
Was the car warmed up properly before the MOT test? A cold car can give incorrect readings.
Have a look at the following link - may be useful
http://www.petercoopercarrepairs.co.uk/new_page_3.htm
Paul
Offline Len
Re: Emmisions Fail!
« Reply #11 on: 10 June 2009, 14:54 »
Oh yes the car was well warm and the tester gave it lots of revving and running!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: Emmisions Fail!
« Reply #12 on: 10 June 2009, 14:59 »
Yea thanks for that Paul, interesting reading!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: Emmisions Fail!
« Reply #13 on: 10 June 2009, 15:00 »
when were your plugs changed last ?
Ummmmmm........
Worth a check I suppose!
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
  • The bear that khares
Re: Emmisions Fail!
« Reply #14 on: 10 June 2009, 15:01 »
ok, well check the wallet for £20 and offer them to the tester next time, should pass with flying colours  :laugh:
Offline davero
Re: Emmisions Fail!
« Reply #15 on: 10 June 2009, 15:51 »
Pretty sure you will have checked this, but check your map sensor hose for leaks( the one from
the T.b. to the ecu ). This caused my emmissions to skyrocket on my old 16v
Offline Len
Re: Emmisions Fail!
« Reply #16 on: 10 June 2009, 16:11 »
Yea will do, that pipe needs replacing anyway coz it was bodged before!
The tester guy did suggest checking all breather hoses!
Plugs are fine! No nasty deposits! Likewise the dizzy cap and rotor arm.
www.sas.org.uk
www.the-ace.org.uk
Offline AudiA8Quattro
Re: Emmisions Fail!
« Reply #17 on: 10 June 2009, 16:16 »
Try some cataclean, i've used it to get old single point injection polo's through the test.
You can buy it from GSF.
Offline Len
Re: Emmisions Fail!
« Reply #18 on: 10 June 2009, 16:22 »
Here are the actual figures:-
Fast Idle 2500 - 2850 rpm
CO = .58% should be 0.3%
Natural Idle 725 - 925 rpm
 0.68% should be 0.5%
He did a Second Fast Idle test and the was worse at 0.63% But the HC came down from 71ppm to 45ppm.
www.sas.org.uk
www.the-ace.org.uk
Re: Emmisions Fail!
« Reply #19 on: 10 June 2009, 16:23 »
Have you failed on hc as well?
Are you burning oil?
