Author Topic: the megasquirt conversion starts urm now  (Read 3986 times)
Offline danny_p
Re: the megasquirt conversion starts urm now
« Reply #10 on: 11 June 2009, 21:56 »
todays progress
finished  makeing adaptor loom from MS to a digi 3 connector,  pluged it in turned key, poked it with laptop turned key again,  and it went brum yay.
unpluged the ms  plugged digi 3 back in went back in house
all the VW's have gone bar 1.
Offline danny_p
« Reply #11 on: 12 June 2009, 00:56 »
more details will follow and some piccys and possobly vids of it running, but cant really be arsed tuneing it with the std manifold so till the ITBS have worked there way back
VeeDubGTI16v
« Reply #12 on: 12 June 2009, 09:38 »
good stuff.
where did you read up on the tuning side of things? i need to start reading up on it all. im gonna have a go at bike itb's and megasquirt maybe next year, depending on how long the shell takes to finish
Offline danny_p
« Reply #13 on: 12 June 2009, 12:32 »
din't reall read up on tuneing in particular place. i read a bit of theory and messed anotu with a few engines then read a bit more theory  then had the piss taken out of my attemps and given tips by people that have done a lot more tuneing then started comapareing what thay did to what i did and trying to work out why. but what i have found out with pissing abou with ecu's is
tuneing fuel is easy , very easy with a wideband lambda,  spark is where the power and the risk is   ifor the sparck tabels on mine i plan to get it close ish then i'll take it to a rolling road and have it tweeked there, as more advance dose not mean more power  tomuch retard or advance just mean things get to hot
VeeDubGTI16v
« Reply #14 on: 12 June 2009, 12:46 »
it sounds like one of those things where you have to get stuck in and learn as you go really. should be fun though! the wiring and installing sensors etc looks easy enough
Offline danny_p
« Reply #15 on: 12 June 2009, 14:46 »
its very easy on the abf ALL the sensors you need are allready there and they are all compatable with ms.  hence why i kept the digifant 3 loom
Offline sidecarphil
« Reply #16 on: 12 June 2009, 18:00 »
how easy is it to get running ??
i am a mechanic with quite a lot of electrics experiance but a bit nervous about starting this
is it a complete ECU build or do you buy it from somewhere ???
Offline danny_p
« Reply #17 on: 12 June 2009, 20:45 »
Ecu came in kit form, built a few of them now,  if i build any more of them i won't be buying kits tho i'l get the boards and prossesors from B&G  and source the componets myself,   i'll put some build photos of another ecu up that i'm building thats most likely destined for tc's car.  but my ms bild is not exactly standard as i've added in a few of the optinal extras .
tbh  assenbeling the ecu is pritty easy if you have a decent solering iron,   the biggest recuring problem i've found is the bloody laptop no speacking to the MS,  vista + usb adaptor can piss you around for hours on end sometimes for no apparent reason  :angry:
apart from that if it's all wired right once the basic setting are dialed in right it'll go.
some old photos
ms2 pcb v3,  prosessor not installed, with high current PWM idel driver for VAG ISV
same one boxed up afetr been tested on the stim now been tested with the stim and some of the actual components (the tbs and isv )
Offline DOA
« Reply #18 on: 13 June 2009, 00:27 »
What ignition are you running? Ive set mine up for edis (built it last year for my own car but never found the budget lol) and am thinking of dual coil setup now to keep things sorta simple (the cars owner refuses to use Ford parts lol). Other than that im finished but since the bottom ends been balanced I dont want to go adding a 36-1 sensor wheel to the crank and I dont want to go near a stock distributer.
Offline monzablue16v
« Reply #19 on: 13 June 2009, 14:50 »
I'll be running my 1.8t on a variant of megasquirt, should be arriving next week :)
