Author Topic: Guy's mk1 Rivage  (Read 328904 times)
Offline Guy
Re: Guy's mk1 Rivage
« Reply #70 on: 20 June 2009, 16:41 »
still to do
interior - refurb and tarting up
new hood and headlining
stereo and speaker replacements
bumper respray front and rear
new plates and surrounds
wheel refurb
fuel filler neck replacement
TAKE SOME f**kING PICTURES
Corrected it for you, dont mention it  :wink:
thanks Jord
actually I need to add the following to the list  :sad:
new suspension (one of the rear springs is cracked)
top mounts
bushes (& possibly wishbones)
alternator belt
water pump, thermostat & seal
side flange (plastic)
front flange O ring
timing belt and tensioner
rocker cover gasket
rocker cover
k-jet fuel pump relay
fuel filler cap
Offline Guy
« Reply #71 on: 23 June 2009, 16:43 »
everything is ordered apart from the rocker cover and the new suspension... all just has to go on now
started off slooooowly with the fuel pump relay... at least it is the right one and at least it works correctly now!  :laugh:
Offline JC
  • Back in the North.
« Reply #72 on: 23 June 2009, 21:06 »
that says alternator belt  :rolleyes: :lipsrsealed:
oh and did u get antifreeze ?
Offline Guy
« Reply #73 on: 23 June 2009, 21:58 »
yes... says alternator belt and water pump!!  :laugh:
Offline Guy
« Reply #74 on: 28 June 2009, 20:03 »
things are becoming frustrating... cannot change alternator belt because the water pump needs replacing
cannot change water pump because the alternator needs to be removed
cannot remove alternator because the hex head is rounded  :angry:
Offline Horney
« Reply #75 on: 28 June 2009, 21:10 »
Welcome to old car ownership, when it goes right it's all the more sweeter.
Nick
Offline JC
« Reply #76 on: 28 June 2009, 21:12 »
 :lipsrsealed:
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #77 on: 28 June 2009, 21:18 »
12mm socket and a hammer are your friend.
Offline Guy
« Reply #78 on: 28 June 2009, 22:22 »
cheers chris - we tried all we could think of  :sad:
http://www.golfgtiforum.co.uk/index.php?topic=121170.msg1066863#msg1066863
Offline Guy
« Reply #79 on: 29 June 2009, 18:46 »
new microwave alarm and sounds fitted... priorities on the sounds are questionable coming before all the other stuff has been sorted... but at least I can drown out the sound of the water pump now!  :laugh:
