Author Topic: Guy's mk1 Rivage  (Read 339701 times)
Offline Guy
Re: Guy's mk1 Rivage
« Reply #410 on: 21 August 2013, 23:41 »
oook so had a brake light issue the other day.. checked and replaced the fuse, still no worky, then checked the brake light switch.. that seemed fine.. so rechecked and replaced the fuse again and bingo... they were working again..
decided to check all the fuses and replace them all, in the correct order!!
fuse box before by Guy Frankland, on Flickr
fuse box after by Guy Frankland, on Flickr
also replaced all the poppers on the tonneau cover... it fits correctly now instead of flapping all over the shop when i'm driving.
had a go at the dodgy drivers door card the other day too... from hangy flappy down upholstery to fitted and restapled with a handle that actually does what it is supposed to do thanks to Chuff  :wink:
from this...
interior in need by Guy Frankland, on Flickr
to this...
door card by Guy Frankland, on Flickr
not perfect but it's an improvement! :)
Offline Guy
« Reply #411 on: 29 August 2013, 23:30 »
so its been a few days... ECP were having a -30% sale on service items so I ordered oil filter, 5L 5W40, new air filter, new spark plugs etc...
ran some wynns engine cleaner through the system
popped it up onto a chuff ramp
Chuff ramp by Guy Frankland, on Flickr
drained it and replaced the oil filter
replaced the air filter too, the old one was orrible
New and old air filters by Guy Frankland, on Flickr
tightened up the rocker gasket as that appeared to be leaking somewhat
gave the bay a clean, not perfect and needs a lot more work!
Engine clean by Guy Frankland, on Flickr
also replaced the MFA stalk as the original was knackered.. the MFA selector had sprung out of the stalk and was determined that it wasn't going back in!
Mfa stalk replacement by Guy Frankland, on Flickr
have obtained some hardboard for the door card replacement - hope to get around to cutting them out to template, waterproofing them and building them up with the original components from the existing cards.
Offline Horney
« Reply #412 on: 29 August 2013, 23:47 »
Good work buddy, glad to see it getting some love!
Offline Guy
« Reply #413 on: 30 August 2013, 00:08 »
 :smiley:  its running as sweet as a nut now... best yet
Offline Guy
« Reply #414 on: 01 September 2013, 19:48 »
stripped out the carpet today to check that everything was ok after last years deluge  :whistle:
pleased to say it was...
Interior cleaned by Guy Frankland, on Flickr
added a bit of sound deadening
Sound deadening applied by Guy Frankland, on Flickr
and then popped it all back together  :smiley:
Offline SoundillusioN
« Reply #415 on: 11 October 2013, 01:19 »
Looking really well Guy.
Offline Guy
« Reply #416 on: 04 May 2015, 22:52 »
so the red banner at the top of this post is telling me that i haven't posted for 120 days... i think that is more like 1.5 years!!
ha!  :laugh:
the car is going very well... have been doing all sorts to it. its my daily and driving very well.. popped a new starter motor on today and some other bits too.
« Reply #417 on: 05 May 2015, 02:15 »
ha!  :laugh:
Same here pretty much.  such a bad member at the moment  :embarrassed:
Offline Rhyso
« Reply #418 on: 05 May 2015, 10:15 »
At least you both still own / drive Golfs  :laugh: :laugh:
« Reply #419 on: 05 May 2015, 14:43 »
Well, good job I drive a 7 which also backs up your comment.  because if it wasn't for that.  it would just be "own"
Poor old MK1 has been on axel stands since I moved house.
