Author Topic: Guy's mk1 Rivage  (Read 339844 times)
Offline Guy
Re: Guy's mk1 Rivage - NOW WITH ADDED MOT
« Reply #340 on: 16 May 2011, 20:07 »
Hood Hydraulics
rightyo... did a bit of a check and top up on the hood today as well as lubing all the joints
I followed Madone's advice in this thread... topping up cabriolet fluid
but there was a big difference between the fluid level when open (max) and when hood closed (below min) - this doesn't seem right to me?
also... devised a neat, very accurate, little method of topping up the reservoir... used a pump and a couple of tubes that I had lying about in place of a funnel, which I didn't have lying about...
Untitled by Guy Frankland, on Flickr
the hood appears to be functioning very happily... just wondered if the levels are being reading correctly?
Offline Guy
« Reply #341 on: 16 May 2011, 20:08 »
also... opened up a small can of wormz  :laugh:
this wiring needs a tidy up!  :grin:
Offline JC
  • Back in the North.
« Reply #342 on: 16 May 2011, 20:09 »
WTF is that  :shocked:
oh and found ya fishy smell yet ?  :sick:
Offline Guy
« Reply #343 on: 16 May 2011, 20:10 »
2 litres of brake fluid and a tin of stop a leak radiator stuff  :wink:
and i dont think wednesday will be paint day, more garage clearance  :shocked: :lipsrsealed:
is it wynn's stop leak? could be mine... but I can't remember ever using it... must have been for emergencies  :laugh:
Offline Guy
« Reply #344 on: 16 May 2011, 20:11 »
nope to the fishy smell and that is a n/s rear light cluster, apparently
I am sure Horney will want to have a look and a second opinion on Sunday  :laugh:
Offline JC
« Reply #345 on: 16 May 2011, 20:19 »
Yes its Wynns and genuine VW brake fluid
does it still smell fishy then ?
and if the weathers crap at any time this week run it over and i will sort it out, and ya door  :wink:
Offline Guy
« Reply #346 on: 16 May 2011, 20:32 »
mate.. can always pop up!
i can't smell it as such.. i think it is either a. damp or b. a foreigner c. a the hood or 4. natasha  :lipsrsealed:
Offline JC
Re: Guy's mk1 Rivage - HOOD HYDRAULICS QUERY pg.35
« Reply #347 on: 16 May 2011, 20:56 »
if you need stuff doing and havent got any DIY to do then pop up, I am in all week  :wink: will sort out the few bitz
Offline Guy
« Reply #348 on: 16 May 2011, 21:15 »
schweet  :cool:
« Reply #349 on: 16 May 2011, 21:22 »
The difference will be the rams being open and then closed, from memory the fluid level will rise when open as the rams are closed, with the hood shut they open and take the fluid.
Hope this makes sense  :smiley:
