Author Topic: Guy's mk1 Rivage  (Read 339716 times)
Offline Guy
Re: Guy's mk1 Rivage
« Reply #280 on: 04 May 2011, 13:12 »
thanks Jack :)
tis a FAIL I'm afraid
nothing too drastic though..
side offside indicator not working - fixed by giving it a whack  :wink:
screen washers not working - fixed by giving the connector a wiggle :wink:
nearside track rod end - excessive play
advisory - nearside handbrake 30% down - probably caused by the fact its been sitting doing not very much for the last god knows how long and it is slightly seized... Chuff said he has a solution for this  :lipsrsealed:
as you can probably tell the track rod end presents a bit more of a problem.. its under investigation at a friendly local garage who is going to take a looksee... if it does need a new steering rack then all is not lost as it needs to be safe.. would rather have the problem sorted properly.
garage will call me tomorrow with an update.. free retest within ten days
so all in all very pleased, nearly back on the road and nothing too much to worry about... everything else, including all the bits Chuff and I have done is peachy  :cool:
Offline JC
  • Back in the North.
« Reply #281 on: 04 May 2011, 16:39 »
i was more nervous than when i take my own cars for a MOT . . . . . .
Offline Jack3559
« Reply #282 on: 04 May 2011, 16:40 »
Sounds like a pretty simple fix. :afro:
Get in there, just in time for summer too!
Offline Guy
« Reply #283 on: 04 May 2011, 19:56 »
We were both pacing up and down like expectant fathers! What was it Arfur Daly said to you.. "you look like you're about to take an exam?!"
Offline Guy
« Reply #284 on: 06 May 2011, 07:50 »
Needs a new steering rack plus two hours labour.
I really don't mind this as it needs to be safe on the road and rather than doing the minimum I want it all tickety-boo! Collect Monday or Tuesday :cool:
« Reply #285 on: 06 May 2011, 09:17 »
Nothing too major then  :cool:
Offline Guy
« Reply #286 on: 11 May 2011, 00:09 »
pickup is being delayed, due to a slight technical hiccup, until friday/saturday
Offline gibby
« Reply #287 on: 11 May 2011, 18:43 »
Check GPC for some new door clips, if they still do them. I had a mare trying to sort out those on mine, the old ones just would not work. Got some new ones and they fixed it straight away.
Nice to see this one coming along nicely.
......now officially dubless.
Offline JC
« Reply #288 on: 11 May 2011, 18:45 »
its not the clips that are the issue gibby, the actual holes in the door frame are goosed  :shocked: looks like they have been filed out at some point  :huh:
2 repair plates fabricated at work to go behind them, and we should hopefully be sorted :afro:
Offline gibby
« Reply #289 on: 11 May 2011, 18:47 »
Ah. Get ya. Good work Chuff. :afro:
