Author Topic: Guy's mk1 Rivage  (Read 329216 times)
Offline JC
  • Back in the North.
Re: Guy's mk1 Rivage
« Reply #170 on: 09 February 2011, 14:49 »
Your not much help then, will be posting up the issue later  :cry:
« Reply #171 on: 09 February 2011, 15:07 »
well, 2 sheared bolts but the whole front end suspension is now apart - what a crap set up having inserts   :rolleyes:
piccies to follow  . . . . . .
I take it the car already had an insert setup and works with the replacment kit?
yep, next issue inner anti roll bar brackets  :lipsrsealed:
What issue are you having.
Offline SoundillusioN
« Reply #172 on: 09 February 2011, 15:09 »
Well you've not said what it is yet.
Offline JC
« Reply #173 on: 09 February 2011, 16:46 »
Problem is  http://www.golfgtiforum.co.uk/index.php?topic=182015.new#new
As for the update .
Mr F was here quite early so we crack on.
Anti roll bar turned out to be a tw4t - i sheared one of the INNER bracket studs - see above link , then guy sheared one of the other studs  :grin:      One All.  :laugh:
But finally it was off and not in that bad condition.  :smiley:
Next up were the  lower arms, a relative easy process as the 2 main bolts had been loosened last time to make sure the captive nuts didnt spin  :cool:
then the front struts came off swiftly and were taken into work to have the springs removed, and THANKFULLY the main nutz came off with a spot of gentle encouragement from Mr Hammer.  :smug:
The inserts were fooked and had leaked a LOT, the top mounts were fubar'd and the ball joints arent very ball like.
So, next up was a spot of cleaning for Mr F,  and he has taken the front struts away to give them a new lick of paint
That was about it for today as i tw4tted my back into the vice on the workbench and was liable to get Mr Hammer out again  :evil: :angry:
And a few piccies
Shiney Bitz  :cool:
Look mum, no suspension  :laugh:
and he makes a good scrubber  :grin:
Next up, fix the issue  :rolleyes: buy some more bits and then rebuild  :cool:
« Reply #174 on: 09 February 2011, 16:54 »
Not sure on the anti roll bar issue.
One small point, when you fit the inserts put a tiny amount of old engine oil in the housing, stops the insert rattling.
Offline Guy
« Reply #175 on: 09 February 2011, 16:57 »
new spring plates on order... so I have two old ones going up for sale... I'll paint em up when i do the struts
pinch bolts purchased... they look different from the originals (same length and dia though) but I was assured they were correct
have been told by GSF that the bush kit for the wishbone WILL fit... and that it will stretch once inside the wishbone... looks like it is going to be a slag to fit  :lipsrsealed:
Offline Guy
« Reply #176 on: 09 February 2011, 16:58 »
into the strut housing?
Offline Horney
« Reply #177 on: 09 February 2011, 19:07 »
Yup.
Nick
Offline Guy
« Reply #178 on: 09 February 2011, 19:10 »
cool.. how much.. like 5ml?
Offline Horney
« Reply #179 on: 09 February 2011, 19:16 »
I just gave them a light coating so they were slippery.
nick
