Author Topic: Wiper relay  (Read 4357 times)
Offline richandhazel
Re: Wiper relay
« Reply #10 on: 17 August 2004, 17:44 »
Cheers mate. How are you getting on with yours? Got it over to Gaz's yet?
Offline SoundillusioN
Re: Wiper relay
« Reply #11 on: 17 August 2004, 17:51 »
Gaz couldnt do it in the end, he had stuff going on and so did I.  I left it a little late and then he had to move house.  Oh well, putting together a plan B me thinks.
Re: Wiper relay
« Reply #12 on: 17 August 2004, 17:52 »
^^^^ dont suppose i could have the diagram of the relays. as none of my diagrams show whichone does what.
thanks
Your e-mail is hidden, could you pm it to me please.
Offline samco-jack
Re: Wiper relay
« Reply #13 on: 18 August 2004, 20:39 »
HELLO BUDDIES I'V JUST BEEN DOWN TO MY CAR AND THE WASHER JETS ARN'T SQUIRTING .SO THIS WOULD SURLLY BE THE RELAY .WOULDN'T IT?
Re: Wiper relay
« Reply #14 on: 18 August 2004, 23:32 »
I'll have to look up the wiring, but if you can't turn off your wipers or use the jets, than it could still be the stalk as both the actions are controlled from it.  Can you change the speed of your wipers? Or pull down to Intermittent?  ???
Offline samco-jack
Re: Wiper relay
« Reply #15 on: 19 August 2004, 17:53 »
HELLO  MATE ,YER I CAN CHANGE THE SPEED OF MY WIPERS .THE SLOWEST SPEED THERE GO AT IS INTERMITTENT.WHAT DO YOU THINK?
Re: Wiper relay
« Reply #16 on: 19 August 2004, 18:09 »
Intermittent is via the relay, still think it could be the off position on the stalk, but then with the washer jet problem too?  ???  If you can afford a relay I'd get one to see.  Might be worth unscrewing the covers around the steering column (3 screws) and just check that there's nothing loose there.
Offline samco-jack
Re: Wiper relay
« Reply #17 on: 19 August 2004, 18:20 »
I'LL HAVE A LOOK AND LET YOU KNOW WHAT WAS UP WHEN I FIND THE PROBLEM.
Re: Wiper relay
« Reply #18 on: 19 August 2004, 18:24 »
Best of luck mate.... Sorry I can't be more usefull but leccy probs are hard to solve over the net sometimes.
Offline carrie
  • i can see into your soul and its not good
Re: Wiper relay
« Reply #19 on: 20 August 2004, 16:13 »
thanks for the diagram shaun
samco probably have tried this but is the motor on the washer working ie making a noise if not just check the motor by wiring to battery to rule it out
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
