Author Topic: Turboing the 2.0 16v  (Read 2600 times)
Offline ripplz
Re: Turboing the 2.0 16v
« Reply #10 on: 25 November 2010, 08:40 »
how would you run it though?,would you need a aftermarket ecu and different loom?and i have a mk5 turbo
siting around recon that would bolt up?any imput would be great
« Reply #11 on: 25 November 2010, 08:45 »
You need to strip the engine down and rebuild it with lower comp pistons etc then run standalone management.
Lots and lots of work.  :smiley:
Offline Len
« Reply #12 on: 25 November 2010, 11:32 »
Not the only way to lower compression ratio! Can increase the combustion chamber in the head.
And you actually want higher compression pistons.
www.sas.org.uk
www.the-ace.org.uk
« Reply #13 on: 25 November 2010, 11:38 »
Not for a Turbo you need to drop the cr on forced induction.
Offline Khare
  • The bear that khares
« Reply #14 on: 25 November 2010, 12:33 »
Yup you need low compression stuff, forged internals if you don't want the engine destroying itself, you want a decent cam that will work with the turbo. Have a look here  :wink:
http://www.bahnbrenner.com/
http://www.bahnbrenner.com/vw_audi/categories/251/VW_Turbo_Kits
Offline Ess_Three
« Reply #15 on: 25 November 2010, 12:45 »
On the VW 16v head, messing with the combustion chamber shape will yeild a poor burn pattern....so that's not the way to go.
There is a mix and match set of standard internals that cab be used to give a low compression bottom end, or you can use a spacer plate and 2 head gaskets, or even just two of the ABF head gaskets for mild boost.
Either way...it's lower on compression you want to go, as has already been said.
..but gaining motorcycles.
Offline Ess_Three
« Reply #16 on: 25 November 2010, 12:47 »
ABF cams are fine.
They are short duration but high-ish lift anyway.
Aftermarket cams need to be higher lift, and possible less duration, to work well, or you'll blow the compressed charge straight through.
Offline Stirring Moose
« Reply #17 on: 25 November 2010, 22:09 »
It's not necessarily less duration you're after as such but you do need to limit valve overlap quite severely. It's overlap that'll have your nice compressed charge scooting right on out the exhaust. Obviously, minimal overlap does impact on the cam duration you can achieve though.
S.M.
ABF cams are fine.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
