Author Topic: 8vDigi - I want more response/topend.  (Read 3478 times)
Offline Diamond Hell
  • Opinions я Us
Re: 8vDigi - I want more response/topend.
« Reply #10 on: 06 June 2009, 21:08 »
ok ok , but with the EFI in the 8v work with  16v lump (not 2.0 but a 1.8 16v from a mk2), donT want to be faffing about fitting old injection
Do try and concentrate when you're reading our responses - we're suggesting using Digifant3 from the Golf3 16V - far better and more efficient than either the Digifant2 on the 8V Golf2, or the donkey-style K-Jet injection on the Golf2 16V.
Insert your Golf3 engine, gearbox, loom and ECU into your Golf2 and away you go - no need for a catalytic converter, bang on a tubular manifold and you'll be knocking on the door of 170bhp from the stock motor in next to no time.
And, unlike the second generation MR-2 (featured pirouetting on the cover of CAR Magazine when launched), it'll handle out of the box.
Offline sidecarphil
« Reply #11 on: 07 June 2009, 11:24 »
what do you need to do to the wiring for this conversion on a 1989 GTi 8v ???
i'm also interested in this conversion as it's cheaper than the VR6 conversion i started and the budget was blown within a month !!!
Offline mk2_abf
« Reply #12 on: 07 June 2009, 11:58 »
i would put an abf in they are bullet proof engines and can handdle any abuse you chuck at it i got my engine and entire loom for 200 quid bet 200 i ever spent
Offline sidecarphil
« Reply #13 on: 07 June 2009, 12:00 »
is the ABF 2.0 16v ??
if so what managment do i use ??
Offline mk2_abf
« Reply #14 on: 07 June 2009, 12:07 »
yeah mine a 2.0 16v im using the management from a mk3 16v
Offline sidecarphil
« Reply #15 on: 07 June 2009, 12:12 »
yeah ok but what about wiring for a pre 90 ???
Offline mk2_abf
« Reply #16 on: 07 June 2009, 12:17 »
not to sure i fitted a 90 spec loom just to keep it easy dont take long to do if your going to fit an abf
Offline sidecarphil
« Reply #17 on: 07 June 2009, 14:48 »
but with the 90 spec loom you need the clocks (i now have digifiz) and the fuse box and switches
looks like a chew on , but if i could make my own loom with the GTi loom and the ABF loom i think it is less work and quicker
Offline mk2_abf
« Reply #18 on: 07 June 2009, 16:02 »
i used the 90 spec loom just cause i knew it would run saves trying to bypass the chipped key its all pretty straight forward swapping looms you would need the clocks from a mk3 16v they fit quite nice in the mk2 dash
Offline danny_p
« Reply #19 on: 07 June 2009, 18:26 »
loom wise  you can put pre 90 plugs on a post 90 loom. once thats done it's also plug and play
all the VW's have gone bar 1.
